Wg6100 problem
bonehead
I'll get pix tonight
50 (100%)
1,729CR
I have been testing a few things in my Star Wars cab tonight and came up with a couple of questions.
I have concluded I have a pcb fault as the vectors are all messed up so tried self test and replaced avg chip but still the same. Also replaced game vector rom but no change.
Upon further inspection noticed the spot killer is lit but I still get a picture which seems very odd!! To make sure it's a board fault I plugged the monitor into my tempest and get a lovely full screen and also the spot killer let is still lit.
What could be causing the spot killer led to stay lit even win a fully working game pcb? I have the lv2000 kit fitted.
Will it cause any harm to the monitor to continue running it? Did try google but couldn't find much about it.
Any idea's ?
bonehead2016-10-13 23:04:48
DanP
Administrator
2,232CR
Hey Steve,
The spot killer should light when it detects an out of spec voltage on the X, Y and I think Z axis. Have you measured those coming out of the PCB? Even better are you able to compare them to a known good working set? I'm not certain but it's worth checking if the spot kicks in for an "overscan" where the beam is attempting to draw outside the visible screen. Star Wars by design does a bit of over scanning to achieve it's effects - like in the Death Star explosion sequence. I'm sure I've seen the spot LED flicker a bit when that happens. As I say read up on the circuit to confirm.
Running with a spot killer on *shouldn't* cause an issue, it's doing what it's designed to do albeit not completely. That said I wouldn't leave it running for too long on myself, just in case. Fine for testing but I wouldn't leave it on to play for an extended period of time. That circuit by design isn't used in the general running of the monitor, only when there's a problem.
Cheers,
Dan
bonehead
50 (100%)
1,729CR
Thanks for the reply. The sw pcb set causes the spot killer to light in my tempest no it so I'm sure it has a fault for to bad vectors. The tempest pcb is fine in original cab and no spot killer led lit. When I try tempest on sw monitor it lights the spot killer led but shows a nice perfect picture. That's why a but stumped as to why it would.
Maybe need to google it some more!!!
Monstermug
1,807CR
Maybe check transistors Q801-Q803 on the deflection pcb? I think they are responsible for shutting off Q503 on the neckboard and preventing damage to the tube. As you still get a picture, it wouldn't hurt to check them? Think replacement for them are MPSA06 ND.
