Well Stumped as to what was the problem I decided to bust out the schematics for the P314 deflection board. As I knew it was a deflection issue causing the spot killer to trip, I followed trials from PCB x/y through to the deflection board testing each component for failure. All tested fine up to the Input protection board which the schematics didn't have documentation on.
This is the input protection pcb.
One of the legs decided to fall off again so I tried to solder it back. It was so rusty that it didn't want to go back.
I tested some of the transistors on the IPB and they were bad. The IPB wasn't labelled and there was no schematics on it. I tried to learn how it worked by following what was done. Figured it was some sort of way to prevent damage to the chassis transistors/and or prevent burning on the screen if the deflection wasn't perfect?
Hell, it was causing more problems that it was worth so I decided to just pull it out. I didn't like the way it was put on stilts anyway. They should have at least put some stand off on it to support it. Looked more like a quick fix than anything else.
Anyway removed the IPB board. Saw 4 resistors that needs to be populated at R700 (1.2k ohms), R706 (2.2k ohms), R600 (1.2k ohms) and R606 (2.2k ohms).
On the back of the deflection board there were some diodes strung together. Didn't know what these were for and weren't on the schematics so off they went. (probably another bodge job)
More bodginess that needs removing. (I don't think these are related and you can leave these on your deflection board if you want) I just didn't like it. My space duel didn't need it.
The pcb looked like it's had been heavily worked on before and had a lot of solder pads removed. Nothing looked out of place now though.
Soldered everything back to place and tidied a few nasty solder marks left by the IPB board and went to test it.
Worked beautifully!
Monstermug2016-11-09 20:18:11
