what capkit do I need?
Mame4All
41CR
Heres some pics!
Mame4All2014-08-02 13:01:46
Mame4All
41CR
I can't see the chassis model anywhere. Think I might need to discharge the monitor and take out the chassis to find it
..unless someone knows what chassis usually goes with this tube? Mame4All2014-08-02 05:25:53
Mame4All
41CR
btw the reason im looking into doing a capkit is iv just had this delivered from an ebay auction. it has pretty bad jailbars on it
Mame4All2014-08-02 13:10:56
gunblade
8,911CR
that is a capacitor problem,capkits do not exist as such-a few sellers made up kits for certain models
in your case i am quite sure that is one cap causing that problem-can't remember which one though but its in the heat shield area
Purity
The Oracle
17 (100%)
2,999CR
Mame4All said:
Thnx for the replys all. Am I right that's deffo a cap problem? I'm struggling to find a capkit for this
Safely remove the chassis. Look at caps, and make a note of them and there position. Buy equivalent caps on eBay. Replace caps.
Whether or not this will fix your problem, I don't know
gunblade
8,911CR
Mame4All said:
Sorry what area of the chassis is the heat shield ?
the heat shield is the metal frame that surrounds the flyback transformer and most of the heat producing components are bolted to it
caps can only be tested using a esr meter or capacitance meter,it would be wise to change any electrolytic caps that are close to heat sources in any case
i have the schem in front of me and i would suggest the following caps to change as a shotgun job,
801
612
805
807
433
803
618
804
613
614
611
in regards to korteks you must note exactly the polarity of the cap you are removing as the circuit boards are often marked incorrectly and change each cap one at a time
