What was this machine?
dombutler
5CR
I have this butchered cabaret, can anyone identify it?
I think it could be a Sega/Gremlin Mini, but not sure. The internals are missing, so it the control panel. I has an id tag on the back and the panel below the control panel is glass. Hard to tell as everything, I mean everything has been painted black!
Any help identifying it greatley appreciated. Plans are to put the machine back to original, or close to.
dombutler
5CR
forcefulfil said:
I'd say it was an alca cab.
Prob galaga,scramble
Thanks a million for that! do you know any information on Alca? I just did a quick search and the id plate, coin door and cash box are the same, so it's just a bootleg then?!
Cheers,
Dom.
69er
1,851CR
Agreeing with forcefulfil very Alca and one of their early colour generics more likely Pac-Man (Alca Snapper) as it was their top seller .. most of their scrambles galaxians and donkey kongs were in a bigger single player cabinet the main ID giveaway is the cash box door and frame unique to them in 1980 - 1982 often fully licenced pcbs installed as bootlegs were not so common that early
Some info may be of use to you? From memory as I recall.
Manchester based Alca was a major manufacturer of pool tables in the 70s and moved with the trend to videos and other stuff we had lots of equipment from them and their sales exec was John Etchells later joining hazelgrove pool lots of Alca cabs survived as they were light but solidly made but many people disliked the shiny brown Formica cabs they developed and hundreds of other small cab builders began to supply black ash , oak and mahogany veneer or ‘Fablon stickyback’ woodies on to the market too . Even Atari mini cabarets were made that way .
Their pool tables quality did not compete too well against hazelgrove super league as pockets were bigger and internal access was difficult via end coin door (with same frame) and the slate was attached to the cushion surround
Herondata and others making pool table met stiff copyright issues from HGM sperleague design so Alca Unable to effect any major changes I think got edged out around that time .. bit of a shame but many small operators tried doing conversions to fruits and videos with novelty and payout quiz games switching to the market popular videos but went belly up too as more began to take over (especially with bootleg copies and kits available) tho the big distributors held all the aces buying new stuff from overseas direct. Fantastic time tho to work for one and be a front line engineer on motorways and pubs etc as well as having our own arcade at the seaside , and pool table distribution business which also ventured into video cab manufacture . Never be seen again I fear!
As you point out your mini cab has maybe had a few adjustments over 4 decades but it lives on regardless !!!
69er2022-04-18 12:57:44
dombutler
5CR
Thanks so much for that, great to hear about the history of Alca. In fact this forum is the only souce I have found so far!
The cab looked familiar, it was on ebay with only one picture, so I took a chance on it!
They said a fuse had gone on the screen, so they changed it and it only needs setting up...
It's pretty sad inside! At least it still has coin mechs and speaker!
69er
1,851CR
having bought this ALCA scramble new from Alca this here was pictured with my eldest daughter (now aged 41) testing out our home upgrade to a 'genuine' donkey kong ( no marquee at the time so improvised ) which we commonly did . the cabinet was already approaching a couple of years old ..
the point being the coin entry door and frame probably modelled on Williams pinball doors for the previous 20 or so years with a S1 single coin slot typical of the Alca cabs of the era ,, your double entry door is likely an upgrade too as it appears slightly off centre ?????? and a newer style frame too .
i could be wrong as it may be a copy cab in itself too and using bits but the speaker position also tallies with Alca but its just an info add into your thread topic ...
dombutler
5CR
well I did go and measure the coin door, turns out it is in the center! And looks to be original, as there is wooden reinforcing strips around the coin door opening (they look factory). The coin chutes line up as well.
I also cleaned out the back, it took all of 1 minute to do!
Note the cut and turned monitor panel fixed in lower down.
Also, there looks like there was another id tag or plate on the back:
dombutler
5CR
Thanks forcefulfil and 69er for the help, yesterday I drilled out the cash box door lock and found this sticker on the back of the door:
Does anyone have one of these cabs?
I'm looking for pictures!
Cheers,
Dom
dombutler
5CR
Look a shed load better already !!! Nice to see her complete. What you Game / Screen you going to stick in it ?
Galaga and 14" crt, not got either of those, but going to wire the cabinet as original and just use whatever until I get the parts.
I have already drawn the screen bezel, just need to finish the front marquee now.
