Which coins do it need?
G
Guests
Guest
Hi all
Sorry if this is rather obvious but i have no idea what i need...
Got these coin mechs:
What era coin would i need for these to actually work? They are both 50p mechs so i don't think the x2 10p will work correctly as these only read 50p's right?
I know i can just open the door and trigger it manually but i want to actually coin up some times plug Twin Galaxies actually prefer you to coin up properly and I'm going for a WR.
Any help greatly appreciated.
rotunda2021-09-26 19:26:40
bones
1,628CR
I believe it to be the old S1 mech. There's an adjuster coin cradle and I've set these up for 20ps and 10ps with a bit of fiddling and adaptation so the smaller coin doesn't miss the microswitch. I'd pop a rivet in the slot to limit a larger coin entering as they tended to block the mech whereas a smaller coin just drops out the reject. You only get 1 pulse which is why most game boards before everything had multi mechs gave lots of coin settings via the dip switches. Alternatively they'd use a credit board for easier adjustment and leave the game board set on 1 coin 1 play rather than having staff misreading the dips and sticking it on Freeplay,£5 a go, cocktail mode, hard mode etc.
bones
1,628CR
There's 2 screws that allow the cradle to slide up and down to gauge the diameter of the coin and another 2 screws that are locked in place by a couple of nuts that are used to adjust to the width of the coin you desire to use. I see it still has the flappy bit to stop the scoundrels pumping washers through lol
G
Guests
Guest
Perfect thank you all. I will get a pre 97' 50p off ebay. The right side coin slot has a rivet in already so i guess it will take 10p too of similar age.
Thank you.
bones
1,628CR
strykr said:
Or just get a couple of 50ps
Yep probably easiest option, just thought if it was just changing to new 50p and new 10p coins(if you have that mech) you could have it done in 15mins max because you'd only need the screw adjustments as the coin size difference wasn't massive enough to cause issues with the microswitch.
The S1 was a versatile mech more so than the S10, they were just easy to spin or launch 2ps past the security bits unlike the S10. Both suffered from strimming and ice coins though. God bless the 70's kids ingenuity lol,my old boss called them snot gobblers,he called them something worse when they sussed that a McDonald's straw loaded with coca cola released through a ms111 mars mech gave them varying credits on the fruit machines.
69er
1,852CR
the fact a rivit is inserted in the facia to me implies its on small 10p already but only the pre 2012 ones made of copper NOT THE NEWER WIDER MAGNETIC ONES MADE OF STEEL you may just find it does not take the new magnetic 10p now as its different width try the LION ones..93-2008 these s1 validators are easy to adjust to one type of coin but rarely able to take both types of the small 10p you can see the difference if you stack 10x 2014 era 10ps alongside 10x 2005 10ps theres a whole coin in stack size difference and the new ones obviously stick to a magnet steel washer catcher if its still present in the mechanism (they can be removed on some)
i used to convert loads of these and inserted a rivit to prevent old BIG pre 1993 tens from being used and jamming the slot
the left side is probably still big 50 as less were used anyway and the games lost popularity by the late 1990s when that coin changed so went away from commercial siting use and more to private owners.
if you do have issues with the microswitch as mentioned above the black rear part does dissemble on a 'barb' clip near the top can be seen in your 3rd picture) to two halves and often there is a small piece of plastic which can be pulled out and moved to enable the switch wire to operate better on smaller coins (or opened wider if you change to bigger coins that will not fit through also ) adjusted by selecting a different set of mounting holes already predrilled for such an adjustment ,,, try the desired coin in the gap near the mswitch wire while its open and listen for the microswitch clicking as it passes through. to ensure it operates ok
69er2021-09-27 11:09:51
69er
1,852CR
giantkeeling said:
Ice coins??
at 53 years old surely you must have heard of these ...... ops never found any just a damp coin box
moulds made from modelling clay of a 50p coins and frozen water in the deep freeze ... kids would maybe get a few mates and use them on the s1 mechs to get credits on popular games like ikari warriors and world cup 90 and sfll etc.. before they melted (most videos of this era could be credited with multiple credits at once using several 'coins' or ice 'blanks' between 9 - 99 credits on some if inserted quickly) and play for ages in the arcades and local shops/cafes that had them...
right size and approx weight to fit through (if not too wide) only detected if the meter said you should have say 6 x 50p coins in the bottom and you actually had NONE
people also mention strimming and strimming alarms on fruits token mechs especially where a coin sized loop made on the end of a strim cable could be inserted and bounced up and down on the micro switch, (the mars multi mech detected reversing coins and usually alarmed)
double timed microswitches also cured that quite quickly when manufacturers got wise
or often a pound coin would appear in the box with a small hole in one side where a strim cable would be glued in to do the same but some mech the coin could not be easily pulled back out and got lost else players often played free.. if they could get the coin back like a fishing line
69er2021-09-27 10:58:37
5,414CR
Oh, thats what there for, learnt something else, so obviously washer gets stuck with that in centre
bones
1,628CR
Another useless bit of info: we had many rat race,ace chase,spoof and win a gain fruit machines set on 2p play £1.50 jackpot. Coin entry was by a mars mech and a S10 2p mechanical mech, we were told to remove the S10 mechs magnet to allow the washers through. Why? well officially it was because the steel 2ps were coming and blockages would happen but the boss also said that the washers were worth more than the 2p now and we used loads during the year.
Ice coins were ideally used in the electromechanical 10p for 2 plays fruities like Ten Ups because the 50p slot was set up to give 2plays and 4x10p change, so if you load the machine quick enough well I think you can do the maths at a time when 20 cigs were 89p and a pint of lager was 49p lol
