Which software? Clone HDD to smaller drive
Sbdesign
SEGA collector
16 (100%)
1,726CR
I have a small Dell optiplex 790.
It has a 250GB HDD running very slow (75GB used)
I have a 120 GB SSD new in box, and would like to clone and down size the drive.
Any recommendations of software? Preferably free.
Im guessing to do the task, I disconnect cdrom drive and hook up the empty new ssd, reboot, and run the software?
thanks for any help.
chunksin
21 (100%)
733CR
I use Macrium Reflect Free Edition, install and create rescue media onto a USB stick then boot from it and with both disks connected, select your source partition and then 'clone this disk' option
Sbdesign
SEGA collector
16 (100%)
1,726CR
THANKS
and does this let you downsize hdd?
Ive only read https://www.easeus.com/buynow.htm, which says it does it, and says most don't, I don't know if thats bull.
Last time I cloned a HDD was probably 20 years ago
chunksin
21 (100%)
733CR
Macrium is pretty smart, I use it for PC imaging and it normally pops a warning message if disk sizes are different then resizes for you
rcantor77
Candy Kid
224CR
I just use the live version of Clonezilla on a USB stick. Have both drives plugged in and you can do any drive, volume and partition work that you need to do.
Sbdesign
SEGA collector
16 (100%)
1,726CR
Cheers everyone
Got it sorted with macrium.
I tried to reduce partition and typical only allowed it to go to 122gb in windows - no idea why.
Ended up downloading more software to do the re-size.
Then cloned it.
All good though and the pc is like new.
Can open pictures again without waiting 2min
Fantazia2
2,246CR
Sbdesign said:
Cheers everyone
Then cloned it.
You might have needed to do a defrag before trying to shrink, also clean out any recycle bin files as I think sometimes they dont show as part of the used space on the drive in file explorer.
Sbdesign
SEGA collector
16 (100%)
1,726CR
Fantazia2 said:
Sbdesign said:
Cheers everyone
Then cloned it.
I read that yea, Cheers. But did it all and still couldn't shrink in windows. Did the reboot and everything any site said. Can't remember the software I used to shrink it, but that worked just fine.
You don't realise sometimes how much these SSD's over a LAGGING slow HDD can be.
I have 3 all in ones to do next. Just ordering the ssd's
thegreathopper
1,253CR
