Williams Defender Missing Colour Blue
Djrouge
119CR
Hi there.. So I treated myself to a Williams Defender, I've never owned one before. Took on one that was in fully working order but needed some restoration work.
Here it is:
When I got it, you had to wiggle the wire for 'Blue' at the monitor chassis molex connector to get blue on the screen. The Molex connectors are desperate for replacement, they've been hacked and soldered and allsorts. Anyway, I'll try to keep this brief and to the point.
Just so you know my level of knowledge, I know the basics, testing voltages, reasonable with a soldering iron, can use a multimeter and have a cheap logic probe, I don't have a TPG, test rig, Osciloscope or anything fancy. Just the basics really, I don't do board repairs unless it's something straight forward. Below is my process so far. Hope you can help.
  • Monitor stopped displaying blue
  • Checked for continuity between the CPU board and monitor chassis (RGB Wires) - getting continuity there
  • Checked that I get blue on the monitor screen if I crank up the blue pot on the neck board - Yes
  • Took out the CPU board and Rom board, removed and cleaned all legs on ROM and RAM chips then reseated them all carefully back in.
  • Had a look for dry solder joints, couldn't see anything obvious but did re flow a few legs that looked suspicious
None of the above made a difference.
Test Menu:
  • Power up and EAM/ROM Reset Tests = PASS
  • ROM Test = All roms OK
  • RAM Test - = No RAM Errors Detected
  • CMOS RAM = OK
  • Colour RAM TEST = No Blue (Red and Green are fine)
I get a single red LED on the ROM Board
Probably should have done this first but I went into the test menu, did a colour rom test and as it cycles through each colour onscreen doing darker and lighter shades of red, green.. I get a black screen when it's meant to be displaying Blue.
Here's what the manual says:
So it's suggesting that 2C or 1C RAMfaulty. Not sure which ones they are, I don't have a schematic that shows me the location of the RAM chip - Can anyone help?
And it also says it could be the 'Color Analogue Circuit' - Can anyone let me know what or where I need to look for this please?
Your help will be much appreciated. I want to go through and make this game good again, it needs a lot of work around the bottom of the cabinet, I just don't know a great deal when it comes to PCB's.
Thanks in advance.
Tony.
Djrouge2021-12-18 22:30:01
Djrouge
119CR
That's great, exactly what I was needing. I'll pull the board again, have a nosey around now I know where to look and will let you know how I get on.
Much appreciated.
Djrouge
119CR
Thanks for the help on this, the fault turned out to be a broken wire about a cm back from the RGB plug at the monitor chassis. You couldn't see it as the break was inside the outer insulation.
The test failing must have been either the game knowing it's not making the connection to Blue at the chassis (which if it is, very clever) or a red herring.
Either way, all's well that ends well.
I'll be posting my progress up on here in terms of how I get on restoring the cab around the damaged corners and bottom and also looking to bullet proof it (as much as is possible on a 40 odd year old machine) making the PSU and everything hopefully look great again.
All I wanted for Christmas, was Blue!
Merry Christmas!
No sooner had I wrote thie post, blue was gone again after I switched the cab off and back on again.
Back to the drawing board.
Djrouge2021-12-28 17:25:30
