Williams power supply
t-m
333CR
It looks like the power supply board in my Joust has had a meltdown at some point and the wiring was then bodged, can someone tell me what sort of connectors I need to fix this? Also is there anything else worth replacing on it while I have it out?
philmurr
48 (100%)
2,374CR
If you're going to the trouble of replacing those connectors that have been soldered onto, replace the rest of them while you're at it.
Also while the board is out of the cab, replace the electrolytic caps too, and clean the fuses/holders
bomjac
453CR
Bob Roberts used to do a complete Williams PSU rebuild kit, but no longer posts outside of the US. Still an option if you can get someone to repost it.
Judder
1,009CR
0.156" Straight Pin Header
http://www.rapidonline.com/Cables-Connectors/10w-0-156-Straight-Pin-Header-22-2630
and then the plugs to connect are
0.156" 10w Crimp Term.housing
http://www.rapidonline.com/Cables-Connectors/0-156-10w-Crimp-Term-housing-22-2540
You can get them in various lengths as you need (the old Defender PSUs have different connectors) and you can also use them to freshen up the connectors to your ROM and CPU boards
You'll also need the crimps for the housing and a crimp tool (ideally, or some pliers and some patience!)
http://www.rapidonline.com/Cables-Connectors/Reel-1000-0-156-Crimp-Terminal-22-2576
BTW I wouldn't rush to go ahead and replace all the parts on the power board - just clean it while it's out - from the power supplies I have the capacitors don't seem to lose much charge and the rest seems pretty robust
tb lilley
5 Star
1,686CR
Not sure Bob is shipping anywhere right now. Website is marked as `closed'.
As above, replace all the connectors and recap the board. If it was me, and this I know is overkill, I'd reflow all the header pins, and replace the bridge rectifiers and power regulators too. That should see it right for about 30 years ...
Equites
Chief Sheesher®
35 (100%)
3,329CR
He is still shipping State side as long as no questions are asked, and order is literally cut and pasted from his website.
