Williams Service Switch Question
iamjimmi
498CR
Hi,
The High Score reset button (used to change game settings) on my Defender has stopped working.
A couple of questions...
Before I replace the switch, is there a way that I can test the switch?
If I need to replace the switch, where can I get one from?
Pinballmania sell a Single replacement button for WPC 4 Test Button Assembly. Red or Black
Would that work?
And lastly, if I did have to replace the switch, what is that resistor that is soldered between the two legs?
Is that needed? If so, what is it?
Thanks!iamjimmi2016-08-28 13:48:16
iamjimmi
498CR
Thanks! As you tell from my question... I am pretty clueless when it comes to electronics...
So... the next question... how can I tell what diode I need to replace this with?
obcd
3,830CR
Use 1N400X with X any number from 4 - 7
Search the internet how to check a switch for continuity with an AVO meter.
Get an AVO meter if you don't have one.
iamjimmi
498CR
Thanks.
Will let u know how I get on.
I couldn't find details of the diode in the manual or schematics but that could be just me not understanding them!
Out of interest, is this normal to have a diode wired across the sevice switch in a Williams cab? Or has mine been hacked?
obcd
3,830CR
It's a normal procedure when input's are multiplexed. I highly doubt it's a hack.
Is there still a wire connected to the other end of the diode? On the picture it looks like the green wire broke off, but it's hard to see.obcd2016-08-29 10:45:12
Hurray Banana
2,761CR
well spotted
