Winding Heat (power issues)
Unit504
156CR
Currently trying to sort the power on a winding heat machine, it looks like someone has at some point changed out the transformer..... and put this on in its place....
What currently happens is when powered up with just the power wires going into the show transformer,
and the transformer connected to nothing else inside the cab.
It just blows the internal 5V fuse and the plug fuse, why could this be..?
No good transformer/duff unit...?
I know this machine is very much like the GTi Club and that has the famous yellow power box!
Would this machine be powered the same way...?
few photos of the machine....
Power distributor block
Thanks all :D
karlcdoe
887CR
I guess if it's plugged into the tranformer and nothing else then logically the tranformer is suspect. However, it looks a little 'funky' in there, are you sure there aren't some live wires flapping around dangerously inside? Has the flex to the cab been damaged in transit shorting it out?
Unit504
156CR
Flex is new, and all other cables/wires are disconnected. It powers up right upto the transformer then when you add it the the layout it just pops! mmmmmm
saleem
111CR
I thought you said on other forum that you didnt have the power hooked to anything and qhen you applied power it blew its internal fuse and the plug.if the power supply isnt hooked to anything and it powers up ok then it isnt the power supply its whatever you are hooking up.so you have voltage wires going out,from 5v & 12v.its probably one of them wires thats blowing the power and plug.
You can do it either the easy way which means you connect the power out from the power supply 1 at a time and see when it pops or you will have to check the job lot without applying power to find suspect faults.you might be getting a short
trm
2,877CR
Hi dude,
Looking at the photo it seems the PSU is set for a 110V feed - just to be obvious and rule this out first is the PSU being run from a step-down transformer or is it being fed straight from the wall?
Has this ever worked whilst it's been with you? Could you also either provide photos showing the power feed as it enters the cab and connects to the various PSU/transformers, or draw up a simple diagram in paint to show us how things are wired and what's connected in? Will make it much easier to troubleshoot.
cheers
tim
saleem
111CR
I said exactly the same and said it was set to 115vac seeing as the switch was flipped to 115vac side on another forum.the thing is i was sure it actualy days 230vac on the switch if you look carefully you can make out the 30.
Unit504
156CR
yes the transformer is not wired to anything at all inside the cab.
route the power travels is...
mains plug into (using an extension lead as no power in workshop currenlty),
plug in the back of the cab,
from the cab plug into the transformer,
thats it.
hope thats a little clear :D
when power is switched on the transformer 5v fuse blows and so does the mains plug fuse.
The little red switch slider on the transformer
is over the the 115v side but displaying 230v on the slider itself.
PaulSwan
ZZZ
1,118CR
Thats not a transformer, it's a switched mode power supply. This type of power supply usually does not start if there is no load attached (nothing connected to the +5V). Therefore, to properly test it you'll need to attach a dummy load so you can measure the voltages. In the past I've used an old Hard Disk Drive, some 10W and 25W can resistors or a 12V car head lamp as the load, attached accross the +5V.
If the PSU blows the fuses with a dummy load, it's likely it's duff.
I'd also use a multimeter to check if there is a dead short on the 5V/12V wiring or PCB in the cab.
Paul.
Unit504
156CR
sorry power supply, so why does it need a load on it to test...?
the power supply blows the internal 5v fuse as soon as its powered on, i dont think adding a dummy load will make any difference..?
PaulSwan
ZZZ
1,118CR
I thought you meant it was OK disconnected but blows the fuse when connected. If it blows immediately with nothing connected on the outputs then it's duff. Throw it away and replace with another one.
Paul.
Unit504
156CR
have now got round to putting a new power supply in, had to de solder all the power in wires from the jamma connector as the old owner had soldered all of them together!!!!
So after a bit of de-soldering and re-soldering back in the correct order.
we tested each part of the machine with the easy bits first, marquee lighting (lol cant go wrong there)
Marquee works fine, monitor needs more attention as it does get power but just makes a clicking sound.
Game board is now getting power but displays a 88 error on the board.
(anyone got any ideas on this one..?)
I to the board to mine and tried it in the gti setup i have and its giving the same 88 error.
I had a GTi Club board do this once and it was down to a power issue..... but am confused as it shows the same error in the gti set which is all running correct.
powered in the winding heat machine:
powered in the GTi Club machine:
hi fixed a few like this before you need to get you volt meter to the +5 v and gnd at the edge connector of the board and turn the voltage ajuster on the ps unit untill you get 5.01 volts to the board then turn off and on, hay presto....
hi not sure but there may be a slite difference in the gnd wiring any how you should check the voltage at the board in its own cab all volts some these old pcb use the -12v to so swapping them over is not a real test.
DanP
Administrator
2,232CR
Are you sure the 88 is an actual failure message or could it just be a bad signal getting to the LEDs? I'd test the power at the IC's first see what you get.
Dan
