Wiring a credit button
itruk
17 (100%)
451CR
After trying (and failing) to recently wire a credit button, I'm here for help lol
I've got a leisure 2000 cab with a Pandoras box v3 fitted, but it doesn't have a freeplay setting.
So I've fitted a normal arcade pushbutton under the CPO and I was wondering where to tap the wires into?
I blew a fuse on my previous attempt of doing this.. So any help is appreciated!
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
1 pin goes to any GND point (Ground) (Common of the microswitch)
Second pin goes to Component side pin 16 for coin 1 and solder side pin 16 (T) for coin 2 (NO of the micro switch)
only coin 1 is needed silverfox07862015-07-26 22:31:14
itruk
17 (100%)
451CR
Quite simple then really!
So, tap into the GND wire and put that to the GND on my microswitch. Then another wife to component side no.16 to my microswitch.
Its a two player cab, but I suppose you only need one player rigged up for the credits.
For the sake of it, am I able to put two wires from both sides to just the NO of the switch?
I don't want to blow anything again!
