Wiring Isolation Transformer
USSCrazybat
28CR
Hi all,
Just started work on my cab. Relieved to find that it did come with an ISO transformer and that I wouldn't have to hunt one down - but when I examined the wiring I was a little confused;
This thick white wire is wired into the iso, but goes down into a mains plug;
Meanwhile the rest of the wire goes across the cab and down the other side into nothing;
Long story short, what am I doing here? As far as I can tell the next step is simply to get my new PSU and harness, wire the monitor up as normal, but also to get a power strip/surge protector and plug both the ISO and the PSU into that. I really don't wanna blow my monitor up so any help would be appreciated
USSCrazybat2018-09-18 14:06:32
t-m
333CR
Looks like the mains lead goes to the connector block, from there it goes off into the ISO transformer. The other wire that goes nowhere was probably connected to the power supply or marquee light.
bomjac
453CR
Possibly this was originally from a kettle-plug type inlet for the cab or or from the door switch (open door, cab goes off, close door it goes on)
USSCrazybat
28CR
I can understand it being connected to the marquee light, but would I need to connect it to the PSU? I still need to research ISO transformers a bit more. It should be mentioned that there is NO PSU in here atm, and the loose wire may have been disconnected before I picked it upUSSCrazybat2018-09-18 17:08:12
Purity
The Oracle
17 (100%)
2,999CR
It's a bit hard to tell from your photos but it looks to me like you have a 240v feed from the plug going into the monitor? That would probably be for the monitor degauss. The other end of the thick white wire goes nowhere, so I would assume that this was connected to the ISO transformer at some point. The ISO transformer would need to feed the Jamma switcher and monitor power
Purity2018-09-18 17:25:24
USSCrazybat
28CR
Well from what I can tell the wire is going into the ISO then the monitor, but also splits off before the iso into that lone wire. It seems to me that the next step would be to hook it into the PSU to provide AC power for the rest of the cab?
t-m
333CR
Well that lone wire would take 240v AC to the switcher PSU which will provide the DC for the game board.
USSCrazybat
28CR
Thanks for the replies. I think I need to have the new PSU and harness in hand just so I can work things out a little more. Would I be right in assuming that I would then wire the white cable into the PSU 3 pin cable, which then feeds into the back of the PSU? USSCrazybat2018-09-18 19:05:07
yorkshire_spam
765CR
1980-20.. said:
What does the isolation transformer do? Mine dosen't have one.
It "isolates" the 2 AC sides from each other.
There is no physical connection between the 220VAC inlet side and the outlet.
Most of what people in the VAC world call an isolation transformer is actually a "step down and isolation" transformer. Ie. it isolates and changes the voltage to the AC level expected by the monitor (and perhaps other parts)
It's possible to have a multi-tap transformer that provides step-down without isolation.
See here:
https://electronics.stackexchange.com/questions/17496/how-is-using-a-transformer-for-isolation-safer-than-directly-connecting-to-the-p
bomjac
453CR
In particular the isolation transformer was usually for the monitor chassis. Older chassis actually had the metal base of the chassis as part of the circuit (eg live at 120v). The primary side of this is connected to the supply as normal (120v / N) but the secondary is simply 120v phase volts with no ground.
So if this was connected to ground you could get a short and blow fuses. Also if it's not grounded (isolated from ground) then if you touch the "live" chassis you are not going to get a shock - think of the birds sitting on a 33kv line. No complete circuit, no electric shock.
More modern chassis don't need the ISO transformer.
