Evening...
Quick one, currently doing a scratch build, first arcade I've done..Its a Ninty, DK cab.
Could anyone point me to a good wiring or "electrical innards' thread please
I;m thinking, I need to
Put a kettle plug on outside of cab for lead to plug into (maybe a switch?)
Push that to the monitor and to a JAMMA power supply. The monitor is original, presumably it wont run off the JAMMA power block?
JAMMA power goes off to board, the PCB has its JAMMA convertor on (or not) and these wires then wire off to buttons and stick and speaker.
JAMMA power can provide 12v to LED strip in the marq.?
Do I need a "ruck" of extra cables to get from board to controls, or will a JAMMA harness have everything at a reasonable length? I've bought some 'ground' daisy chain cables too.
My plan is to drop a button on the underside of the speaker panel, to do coin up. Am I right in thinking the JAMMA harness will have a cable that would normally go to the coin mech and I just wire that in?
Thanks in advance all...
Rob
Rob
