Wms CP illumination
chadsarcade
Lord of Vectors (tm)
443CR
I decided it's time I gave my cabs some TLC and a bit of polish so thought I'd tackle an issued that't bugged me for a while: the illuminated buttons on the early Wms games - Robotron, Joust, Sinistar etc.
these games use translucent buttons which are illuminated under the CP by 6.3v AC lamps. The problem is that very little light actually gets directed through the buttons so the effect is only visible in a very dark room.
Given that we now have high brightness LEDs I thought I'd investigate improving this. I found some drop-in LEDs replacements for the original 6.3v bulbs so bought a few to try.
I used high brightness directional LEDs - the LED itself is mounted on wires protruding from the bayonet fitting so you can position them as you wish.
Quite bright when lit!
And from the CP side:
I'm quite pleased with the results. Purists may not like it, but I think Wms would have used the technology had it been available then.
I've since changed the coin door bulbs to drop in LED replacements too - should reduce the power consumption a smidge and give a better lifespan.
chadsarcade
443CR
Yep -
For the directional CP ones I used >these< in pure white
For the coin door inserts I used >these< in warm white.
The warm white is pretty much a spot on match for the original filament bulbs, but I went with the brightest possible for the CP.
I also cleaned all the buttons which helped as they were pretty manky!
Before:
After:
Edit: no idea why pics aren't showing, they preview OK...
chadsarcade2015-01-11 16:44:48
