Wonderboy in monster land bootleg pcb
sukhbir
45 (100%)
1,603CR
Recently purchased a faulty booty of wbml pcb from a member, nice chap and gave me a good price.
I was told it used to work but developed a fault where the game keeps resetting,anyway here's it on bench.1000010279.jpg
Before powering on i went and inspected the pcb which I noticed it had a open track (circled in red) and 2xred wires soldered on top to bottom on the ground pads?the open track Leeds to the +spk pad and was repaired with a link wire.1000010281.jpg
Looking over the pcb every thing looked ok and no sign of trace damage. Ok now I powered on and surely it was faulty as described with random resetting. I did a romident on all the roms and roms 4,5,6 were not recognised so I burned new eproms 4,5,6 with the correct rom files.
Powered on but fault remains,next I looked at the work ram which sits under rom 7 which checked out ok.I was now at point on where to look next so I turned my attention on four pal chips which I think is used for tile gfx generation ,I scoped all pal outputs until I came across pal(ic32) and one output at pin 12 looked odd on my scope so I decided to get the jed file from arcade pld and burned it on a gal16v8.1000010518.jpg
Powered on and.........
Cooool :D wonderboy is alive!!
Played it for an hour and worked with no issue, controls,sounds,music, graphics spot on.
pooman2084
Be Attitude For Gains!
25 (100%)
1,804CR
It makes me so happy when my old dead boards live again.
This is a truly great game. I’m going to have a go on MiSTer later.
IIRC it all went pear shaped when I swapped the ROMs, they were from Virtual Console I think. Before it was all in amusing Engrish but it made the quiz really tough.
D
Deleted member 7540
Guest
sukhbir, the fact you bring boards back to life is so awesome, but i also love the fact you take time to mention what actually fixed it. You are a wizard with PCB's. My Cosmic Avenger i got from you still works like an absolute charm.
Total legend.
sukhbir
45 (100%)
1,603CR
Total legend.
That’s very kind of you to give such honesty :) on my repairs,as always I make sure I do a proper fix and test.
thanks rotunda (y)
