Hi guys.
The steering wheel on my Sega Scud (sit down) continuously seems to work itself loose when in use. I have replaced the bolt and washer that secure it to the shaft, and although much better, it still eventually works itself loose, which results in the wheel rocking back and forward during use.
I've now started keeping the bezel off and just nipping it up as needed, but would rather find the solution. Is it as simple as pouring a load of thread lock in there and leaving it? And if I did then what if I needed to remove the wheel/dash in the future?
Thanks in advance.
Neil.
Thanks in advance.
Neil.
