Working Tetris Board
cparsonsuk
205CR
So this is "maintenance" but the board does work fine...
I just bought a Supergun setup to test some PCBs I haven't had a means to run for 9 years...
All work how they did last time they were tested but one surprised me ... I have a Tetris board I was close to selling on here a few years back and then I managed to somehow knock off one of the capacitors...
I gave it a quick check yesterday and it still works fine... didn't run it long as guess that might lead to trouble???
I haven't spotted where the capacitor actually goes on the board but wondered what problems one could run into using the board with a capacitor missing?
cNp
obcd
3,830CR
Most boards have decoupling capacitors on the power supply lines. They help to keep the supply voltage stable and decrease high frequency emission of those lines. The placement of those capacitors is not an exact science. Every one or 2 chips, usually a 100nF decoupling is placed and a couple of 10 - 500uF electrolityc might be placed as well. So, one missing might not cause any problems at all. If it really was a critical one, you could get occasional freezes of the board due to the supply voltage becoming unstable. A lot depends upon the quality of the used power supply as well. Digital circuits tend to consume more current when their outputs change state. The capacitors form a sort of power buffer to average those peak currents. So basically, you shouldn't worry to much about it, specially if it was a capacitor between a power rail and ground. If it makes you feel better, just look at some other capacitors on that same power rail and resolder an equal one, unless it had a real different form factor.
  • Like
Reactions: cNp
cparsonsuk
205CR
Thanks for the explanation obcd... I still have the capacitor so will have a close look to see where it came from and if I can replace it for completeness.
cNp
