Xevious dead
Body pop
24 (100%)
1,266CR
I'm struggling with this xevious machine ,board was repaired and monitor was working ok before
I did have it Working for a very short time ,now nothing ,marquee lights and stuff are coming on.
Monitor isn't ,no neck glow or anything
Can't hear board playing blind when I credit it
Fuses are ok ,everything looks to be connected ok
Anyone shed any light please ?
Equites
Chief Sheesher®
35 (100%)
3,332CR
Not unusual for a cab that has been standing so long to stop working suddenly.
I would start with the Power Supply from the brick, ensure voltages are there, work your way up to AR2 then the PCB.
After that, check monitor.
RGP
Meeter & Greeter
2,039CR
Glenn and I exchanged a few emails on this, my suspicion is the brick or the interlock switch.
F2/F3 on the transformer side should have voltage on AC as these go into the bridge rectifier after the fuses but IIRC he wasn't getting voltage there.
I'm thinking something very simple has happened here like the input fuse on the brick or the input line 3-pin molex being a bit flaky.
Body pop
24 (100%)
1,266CR
Thanks guys
Yes James , I think I just need to spend a bit of time on it again , going through what you said in emails one by one .
I feel it's something simple too , one of you guys would of had it going in minutes probably
I must look at that main fuse again ,and replace them all as a starting point , even though they tested ok ,in case as you say one is a bit flaky
Then il work my way back ,the fact it was all going fine ,then nothing makes me optimistic , I've had the ar2 and power brick out just for a visual inspection and all looked well there .
Does the power go through ar2 to monitor also ?
RGP
Meeter & Greeter
2,039CR
No the power for the monitor comes direct from the brick 15 pin molex connector.
The ar2 is powered from this cable as well but if you're not seeing anything across f2/f3 then you've nothing going to the ar2 to make it make the voltages for the board.
Start at the input and check you have 240v getting into the brick after the isolation switch - it could be that your switch is bad.
Body pop
24 (100%)
1,266CR
Bit of a breakthrough ,took fuse holder out as it seemed to be causing probs
Took it out and gave it a real good clean ,ans basically just messed about .
It's now playing blind .no neck glow on monitor ,power is reaching it though
