Zac Invaders repair
bbz149
26 (100%)
1,608CR
Anybody able to tell me if it's straightforward to replace the PROM
daughter board with 3 x 2716 ROMS onto the main board? Also could
anybody supply me the flashed PROMS
Basically I have this board, where the ROM's run very hot, and suspect there might also be a faulty ROM.
And this is a pic I found of the 3 PROMS
bbz1492013-05-07 22:18:17
Macro
2,016CR
The standard mame rom set has 3 roms in there (well, 4, since it also has the character rom), so you would just need those programmed up.
Not sure if you could use 'normal' 2716's, as I seem to recall that the board uses 3 rail eproms
let me dig my one out and see, I seem to recall it only had the three roms for program code. Once we know what rom types it needs, I may be able to sort you some out.
Equites
Chief Sheesher®
35 (100%)
3,332CR
I'm pretty sure they are just 3 2716 ROMs.
4,058CR
It's the daughterboard with proms, 6 x 2708, or 3 x 2716. Cant remember if you need to set wire strap jumpers or not to select the type you use but I suspect you might have to.
I wouldn't necessarily say that just because the proms are running hot that they're faulty. The proms on the daughterboard always run very hot. You could always get someone with a Fluke and one of Mike's S2650 adapters to test the proms in-circuit, eh Mike
bbz149
26 (100%)
1,608CR
Cheers Macro that would be great m8
I did find this info, ring a bell Guddler? Link
Nad I think they might be 2716's going by the link above
Equites
Chief Sheesher®
35 (100%)
3,332CR
They are definately 2716's, as I had to reburn all 3 ROMs to repair this example. It was originally running 2716's, I do not recall seeing any links or jumpers though;
I think the 'Character ROM' may be the large IC in the bottom left with the large white round sticker on it - looks like a MASK ROM.
You can see where I have socketed and replaced all the 2102 RAM right next to that MASK ROM IC.
4,058CR
I can't remember 6 monmths ago, let alone 2005
I do remember doing a hell of a lot with these PCBs at one point though and fixing quite a few of them. Haven't touched PCBs in a very long time now though,
4,058CR
Only because I kicked the arse out of my twenties
Cheeky sod. You wait, you'll pay the price for your current shenanigans eventually!
bbz149
26 (100%)
1,608CR
On another note, anybody know why I cannot get this to display on any
TV's or monitors? It's Pal out and I cannot get it to display a picture
on the bench
Nad sent me a pic of his running on a Plasma, but I've tried it on 4
TV's and a JVC PVM. I thought something else had gone wrong with the
board so I ran back over to mates where the cab is stored and picture is
fine
This is what I get on a PVM
P-Man
International man of mystery
1,273CR
The Invaders has a strange sync window, you will need to adjust the pot on the game pcb, along with your horizontal position and horizontal frequency on your monitor in order to get a good picture.
There is not a problem with your rom board, don't change it. These are 4-bit proms that naturally run hot, very hot. This is normal.
bbz149
26 (100%)
1,608CR
Yeah real pain in the arse to get an image
Not sure ill try messing with the TV's HF and tried the pot near the video out and no change
ill have to see if there is an internal horizontal frequency pot inside
the JVC PVM, if not after changing the RAM's ill just have to pop i
over to my mates again!
bbz149
26 (100%)
1,608CR
Well I pulled all 8 RAM's and thanks to Nad for replacements I installed new socketed ones
Fired it up on the same monitor I could not get a proper picture on and got a complete Invaders screen
Even though I got a picture in the cab itself!
Then the graphics as in pic started to go funny
Now every time I turn it on I get this or worse
Any ideas?
