Zaccaria Astrowars Audio PCB
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
I managed to download it but my Corel Draw X5 wont open the file
its giving me an error message
silverfox07862014-08-23 14:16:38
piero.a
8CR
Saved version 15
https://dl.dropboxusercontent.com/u/34851970/Audio_Astrowars_Zaccaria_15.cdr
just some minutes to finish upload
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
I managed to open the file but I think you either didn't save it to maintain layers or its didn't save them all I can see is the silkscreen layer and cant toggle layers as they are not there
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
ok let me install X6 and get back to you
EDIT:
I opened the file in Corel Designer (my preferred program) and now I can see all the layers
YAYsilverfox07862014-08-23 17:41:14
piero.a
8CR
I took the image from manual and I checked socket and connectors dimensions. They seems to be right. Paul Swan confirm the right outboard dimensions but another check is not bad
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
looking at what you made it seems easy enough to reproduce but using todays programs and all the requirements for PCB printing it wont looks the same, the main thing you will see is there wont be any curves traces but rather straight and angular, I am happy to reproduce this for you as long as you are aware that it may not looks exactly like the original but will function like the original
the program I use is very basic pcb designer which works well for me but for older PCBs that where etched and didn't need to comply to anything it wont be the same
I would still like to see a pic of the pcb and a BOM so I can outline the board better and also will help me determin the solder mask which I think is a GND plain
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
I been looking at the layers and saw the actual pcb solder side
I will start it today
are you sure you want it the same size as from what I see there is a lot of wasted space on the original which will just add to the cost of having it made as most companies charge by the square inch
I found a BOM so can use that. would it be possible to get a picture of the component side so I can see the components to double check as im unsure of the 18 pin CIS receptacle (CN1) and 6 Pin Male (CN2)
