zaccaria the invaders
steve_lacey
6CR
Hi
Has anyone got a backup of zaccaria the invaders 1978 3 rom 2516 tms type? rom A3 (inv 1-2), rom A4 (inv 3-4), rom A5 (inv 5-6)
Board is 1B1120 revision. It uses 2650 cpu by Signetics. It has a daughter board sound board. It is also a composite tv output, black and white, not RGB.
My roms are corrupted and most pins disintegrated on removing them and i couldn't save any of them by soldering a socket to them either or new pins, probably heat damaged anyway afterwards. :(
My old rom programmer data i/0 288 with 388 rom pack can reprogram them luckily enough if you have any.
steve
Lurch666
21 (100%)
4,505CR
Try the mame ones and if they don't work I have a backup of the roms from my boardset.
I'm pretty sure I checked mine against mame and they matched.
5,409CR
Talking of Corrupt roms, member is looking to burn new rom on his Op Wolf Bootleg, it's Bootleg like Op Bear but it's not same, Op Bear doesn't have Name at start just red dot goes up screen where as the other bootleg like I have has Operation Wolf like original
Still doesn't seem to be any Op Wolf Bootleg apart from Op Bear and there are a few about, my roms are soldered in the pcb though
