Zaxxon sound
cmjones01
194CR
Hi all,
I've recently been getting my Zaxxon PCB up and running. Actually, it's a 'Jackson' bootleg, but that doesn't worry me as far as enjoying the game is concerned. I had real trouble with the sound - it was accompanied by a thumping noise which came and went more or less randomly. I recorded it here:
http://www.youtube.com/watch?feature=player_embedded&v=n7rfCbffPIQ
I'd read about the little electrolytics all over the sound board being trouble, but they were all OK on mine. I replaced the big power supply decouplers (two of them were physically broken) on the sound board which helped a bit but not much. Eventually I tracked the problem down to good old-fashioned motorboating, an interaction between the power amplifier, signal source and power supply. Most of the gory details are here:
http://martin-jones.com/2013/02/20/motorboating-in-space-2/
I noticed that the voltage-controlled amplifier chips on Jackson are different to the official Zaxxon ones, which might contribute to the problem. Has anyone else has this sort of trouble with a Zaxxon/Jackson board? Is it known to be particularly sensitive to the stiffness of its 12V supply?
Chris
  • Like
Reactions: trm
trm
2,877CR
Great write-up Chris. I've not encountered motor boating effect before* - the most common audio issue I get after blown op-amps is ringing and a cooked amp.
(*Well, not the motor boating effect you're talking about here
