Zero delay usb encoder versus ultimarc
Right - time to laugh at the novice. Again !
I've been reading all manner of threads, other sites and forums in my thirst for knowledge on fixing up or MAMEing my taito cocktail cabinet.
I was wondering what the difference is between a reyann zero delay usb encoder and the ultimarc iPac 2 with wiring harness and wires that I purchased ?
Is 1 better than the other ?
Do they just do the same thing ?
Have I wasted my money ?
Thanks in advance,
IslandStrife2016-09-12 13:02:22
joe34
448CR
the zero delay usb encoder works in the way that it is recognised and used in windows as a game controller
whereas the ultimarc stuff is a keyboard controller
it's better to use the ultimarc stuff (easier to get going/use, works with more stuff, more configurable, etc)
the zero delay encoder is ok for a quick cheap easy basic project.. by the way it's debatable if they really are 'zero delay'.. anyway, i would always go with ultimarc because they are better quality and more reputable than the cheapy stuff
Thanks for clarifying Joe.
Glad to see I purchased correctly in the first place and that you guys are always on hand with a good steer information wise.
Jez
Since I'm on the subject of help.
Where could I buy all the "insides" for my cab as opposed to MAMEing it.
It literally only had a cp and coin mech,but no monitor, game boards or psu.
Is it pointless or should I consider it ?
strykr
1,351CR
Wanted section
Its going to be tricky and fairly expensive to get all the parts, depends how much you want it to be closer to a proper arcade experience and how handy you are. Maybe as this one is a shell mame it up and look for a generic jamma cab for boards and mame if you wish.
joe34
448CR
hi again, im not sure exactly what it is you are doing,
could you list all the bits you have, and all the bits you need
and also, what is your level regarding the technical side, such as setting up mame and getting the mame pc to work with a monitor (what type of monitor are you hoping to use, eg. crt tv, crt pc monitor, lcd monitor, arcade monitor...) ?
Lol. I don't know what bits it needs !
It's an empty taito cocktail cab with a crazy looking 2 player CP on one side and a coin mech.
No monitor, PSU or game board or anything like that.
Just was wondering what it.might cost to buy the electrical boards and PCB, psu and wiring harness ?
I'm a complete novice, but have had mame running on old pcs for a good few years
