Problem Toei cm-r20 Green issue?
gunblade
22 (100%)
8,831CR
so someone has replaced the heater resistor with a short as the picture was dull, i wonder how much voltage the heater is getting - you will not be able to read the heater voltage without a high quality bench meter
Ronnie Dent
1,156CR
Actually the image is not bad! Weird! Colours are maybe a bit off but seem to be there, can’t seem to get full vertical deflection and the scores are a bit squashed at the top?
