Ah, that's an issue then! Need to see if I can setup a 60 in 1 to at least feed the screen, thanks again Grant, saves me chasing my tail!you need a signal on it
The screen volts beside focus? Yes the brights and dims image R G and B makes no change, going to rig up a 60 in 1 to it shortlydid adjustment of screen control make any difference?
if not then likely a voltage missing
Grant it’s more like a link wire than a resistor has pink sleevingspecs on schem say 2.2 ohm but its likely reading almost short due to circuit, you could lift one side but i expect its ok
Thanks Grant, been a bit of a red herring the green raster! After twiddling the R G B pots I have a decent image, thanks again for all your help with thisignore it, the 60 in 1 do behave with a verticval lin issue, wait until you get a proper game board on the cab
No Idea! Grant said it needed a signal, with no signal the R G B pots did nothing but did with an inputWhy did green dominate ?
