Had a good afternoon yesterday with Jason the owner, his staff and Will (t-m).
Here's the situation with the cabs so far:
Centipede = Still needs an AR2, I might grab one from forcefulfil if he still has any going.
Xevious = Working, Monitor has some black / tearing at top but otherwise okay. Perhaps re-capping the chassis will help?
Alien Syndrome = Boards confirmed as working properly! Old monitor and marquee light fixture taken out, Jason is looking to fabricate a new wooden frame for a replacement monitor he has to be used. t-m was converting it to 240 volts when I left.
Here's the dimensions of the control panel: Width (visible area) = 23.5", Height = 15.5" + 3" folded over at the bottom. The "hole" for the plexi is: Width = 12.5", Height 3"
Space Invaders = t-m tried to get the boards working, they were for a while but have now stopped working altogether.
Gorf = No change, when we tested it last time correct voltages were coming from the power supply, but game wasn't working so probably faulty boards.
Tempest = Powers up, spot killer comes on, nothing else happens for a while then a constant "beeeep" is heard.
Asteroids Upright = Monitor was swapped with the cocktail and doesn't work. Not sure if this boardset is working properly.
Lordsvale MVS = Fully working but monitor is quite dark & contastly, occasionally changes from a redder to a greener hue.
Looking forward to next Month and the event itself, hope to see some of you there!
