My thoughts are that no pcb is worth attempting to fix if you don't have the right kit.. but i'd say this was especially the case if you're a beginner, do not start on a vector game, they are absolute dogs to work on if you're a beginner, with a very very steep learning curve.
If you want to learn board repair, start with an easy raster game like Galaxian, you can sit that on your bench, run it on your jamma rig and poke and prod at it without :
a) fear of damaging a delicate pcb (IC replacement especially, do not learn on an Asteroids!)
b) doing your knees, head, neck in craning into a cabinet as its the only way you can power it
I would reccomend sending the pcb off to someone that can repair it properly and timely. I do repair pcbs, i have a few lined up at the moment and i may be abroad next week, so probably couldn't return it within 3 weeks or so. PM me if you want, or look for somoene else to fix0r it
From this point forward, as has been suggested, you could possibly clip the DMAGO signal to see if the game runs blind, but in my experience if you have sounds firing off, and coin counters clicking, i think you have MPU problems really and clipping the DMAGO is a bit of a futile gesture as even if you did determine the MPU was running, you're looking at a DVG problem, and that is certainly not something anyone is going to step you through while working on a pcb in the back of a cabinet, you wouldn't want to anyway
P-Man2011-01-03 16:54:38
