Installing the internals: Part 1! August 2014
It's time to start what is both the most enjoyable part of the hobby for me but also the most stressful; putting the cab back together! I've been surrounded by boxes full of Star Wars cockpit parts for months now in my games room. Poor old
Indiana Jones and the Temple of Doom has not been switched on for the same period; mostly because there was a 25" Amplifone tube sat right in front of him.
You never 100% know if a machine is going to play nice when reassembled; I've read stories from other members who swore that on the test bench a game ran beautifully but when reinstalled in the cab it crapped out. I've been able to offset the potential for this scenario, at least to a certain point, in that the cockpit internals were purchased from a reputable member (two actually) and have been soak tested by our own
Mitchell Gant. In short, we've done the best we can and I've found my enthusiasm again after the 'it won't fit in my house' pantomime.
I have decided that in true OCD style, everything is going to get a damn good cleaning before the cab goes back together. For the perspex canopy, only a strict diet of Novus 3, 2 and then 1 will suffice and there will be no slacking.
I think it turned out OK! There are 3 panels there by the way but the one on the left is almost invisible for some reason.
First the power brick went into the base of the cab, once it had been swept out and made ready of course. (Neil had kindly transported this, along with a few other bits to my storage as my car was, embarrassingly, full.
Next up was the High Voltage PCB.
Pass me a screw. We don't want that falling out. That would be bad." said Neil.
I pondered for a moment on what 'bad' could mean when applied to a Star Wars cockpit. I had spares of most of the PCBs neatly wrapped in anti-static bubble-wrap at home but I didn't have a spare game board stack and I certainly didn't have a spare 25" Amplifone tube; we had already decided that we would put that baby in last. Mainly because the thought of dropping it was
f**king terrifying. Yeah, let's put that off for as long as possible
The main PCB cage went in without any hassle, with only a smidgen of "
To me, to you, to me...which way does it go in again?" Similarly the AR-II; this one freshly repaired and tested by Neil, slid into place and was secured accordingly with an Atari screw. I noticed as I put the Deflection PCB in its guide rail that both it and the HV PCB were beige:
Those are the earlier revision aren't they? Nice!"
As the loom had been neatly labelled up by a previous owner, actually getting everything plugged in went fairly smoothly. Star Wars cockpit was never the neatest and most cable-tidied cab, even from the factory though and the end results were not surprising!
I am missing an Atari coin door set, the mech and the associated cable unfortunately, so that particular plug is for now left dangling.
I will set the PCB on Free Play so that the cab is usable until I find one.
*cough* Alpha1 *cough*
It was now time to carefully install the Amplifone tube. If anyone had turned up at the storage unit at this point, they would have seen 2 men carrying what looked like a TV v-e-r-y v-e-r-y s-l-o-w-l-y You would think that we were transporting radioactive material, such was the level of care and concentration we were applying to the situation.
A bit quicker, otherwise I'm going to drop it!" said Neil.
This line reminded me of a conversation I'd had with
Muddymusic when we were negotiating the sale. It went something like...
I nearly necked the damn tube tonight trying to fit it in the cab. I've had enough. I need to sell it before I break it!"
Was it really that difficult to install?
I'd removed the top hatch from the cockpit to give Neil and myself as much access as possible but it was still really tight in there.
It's really tight in there." said Neil.
In actuality, it only took 2 attempts to get the tube snugly and firmly in situ; the reproduction brackets that I purchased from Troy on KLOV were absolutely perfect
I'd be lying if I said that was it though; I still need to fit a connector for the rear speakers before it's time to flick the ON switch; no way I'm playing Star Wars with no sound! I've also tested the calibration of the flight yoke on my SW upright cab and it's off by a few inches to one side but that is easy enough to sort. Those are stories for another time though!
Next up: The big switch on!
