mrvectrex said:The info about the acrylic was especially useful, though I checked at B&Q and a sheet will cost me £30 which seems rather expensive. Going to try and source it from a sawmill nearby instead but otherwise will be on the hunt for a supplier.
neil1637 said:mrvectrex said:The info about the acrylic was especially useful, though I checked at B&Q and a sheet will cost me £30 which seems rather expensive. Going to try and source it from a sawmill nearby instead but otherwise will be on the hunt for a supplier.
I get mine from a local glass supplier, I basically go in for off cuts from the massive sheets they get and then cut it to size on my router table with the speed turned right down so as not to melt the edge. I think the total cost for the entire cab was under a fiver.
Failing that option Trent plastics are about the best/cheapest online cut to exact size for you nad really reasonable although the postage kills a bit.
Start a thread to show what you have done so far and then it will give you an audience, whom you can ask for help as you go along.
Good luck
Neil
mrvectrex said:Oh, one more question re: T-moulding: you used 18mm MDF for the sides and I was wondering where you got your T-moulding from? I was looking at ArcadeWorldUK.com but their T-moulding is 3/4in which works out at a fraction over 19mm. Was this the same as you used? Is the size difference noticeable?
Russ
Russ
