My New CVS Choplifter Table - Any Advice?
big10p
Coins detected in pocket!
5,443CR
Sounds like it could be a power issue. Did you check your +5v voltage as suggested? Try increasing the voltage a tad if it's spot on 5v.
Flinnster
The Dino King
29 (100%)
2,562CR
Small hole in the front of the silver switching case is the voltage adjustment.
You'll need a screwdriver to carefully up the voltage.
Only do this while measuring the voltage on the ground and +5v pins using a multimeter though.
