Another update on this project.
I've now added a full function probe arrangement. When set to digital, it will display either Low or High for the logic levels. No problem I hear you say, except this will also show Floating pins, duty cycle and also a indication on what type of signal its seeing. So without using a scope, you can see whether its active low or high or more a clock pulse.
Couple of pics in action.
On the left is the signal probed using a scope. On the right is the same signal probed with my tester.
Reading the display from left to right is as follows: Duty Cycle in %, Type of signal. (Active High), L indicates its a Logic probe and the last o is the activity indicator. One the top line, the first 4 digits are the address and then data is displayed in the right two digits. At the moment no data is present and the address is set 0000.
If the probe is set to analogue, The display changes to display the measured voltage plus a selectable amplifier is engaged to probe for audio signals so tracing sound faults is possible too.
I have decided that I will be building these to order if anybody is interested. Price has yet to be set as need to work out materials and labour.
andrewsm2016-04-17 15:48:38
