Sega Naomi
andrew96
899CR
stick it outside and go over it with a airline making sure the dust doesn't blow back in any wind!
I personally would not recommend trying to go over it with a soft paintbrush or you could knock things about that you don't really want to knock or break
IDCHAPPY
KANFU Master
9 (100%)
1,523CR
So just compressed air then? I'm not looking for it to be so clean I could eat my dinner off it, just not as furry as a family of chinchilla's
IDCHAPPY
KANFU Master
9 (100%)
1,523CR
grobda said:
its all gone a bit otaku...
srsly nice work, hope the innards work... talking of which was there anything in it?
It was a complete cab dude, well when found all the bits(monitor surround and back cover) scattered about the arcade
chubsta
539CR
while i was rooting about the other day i found those 4 white clips that cover the bolts on the front of the monitor surround - if you are missing them let me know and ill send them out, one has got what looks like a burn on the corner but im sure you would be able to do something about that...
4,055CR
I've always just gently gone over my monitors gently with a soft brush and a hoover nozzle to catch it. I've never had a problem yet but as Andrew says, you do need to be a bit careful. And I've never had any quibbles about fixing monitors or indeed anything so I probably do have a different outlook to most people (in that if it breaks I'll fix it
IDCHAPPY
KANFU Master
9 (100%)
1,523CR
Ok, tonight I plan to whip the chassis out and give it a freshen up, then it's just removing the rest of the gear, cleaning the frame then putting it back together
Thanks for the assistance guys
IDCHAPPY2013-09-04 12:54:21
IDCHAPPY
KANFU Master
9 (100%)
1,523CR
4,055CR
Is there anywhere to get "keyed-alike" locks? I may be mistaken but I thought Ordy's were "keyed different" and I hate playing guess the key
trm
2,876CR
I take the barrels out and remove the pins. All you need then is something that fits in the key way.
CLEARLY I don't do this for my house, err.
4,055CR
Ah!!! Now that's not a bad idea
I have about 80 barrel locks that you're meant to be able to "program" with a master key type thing but I don't think I have the magic key as I've never been able to work it out. Might see if I can find them!
trm
2,876CR
Can do a photo tutorial on depinning, common-keying, master-keying locks if anybody wants it.
Or I'll show you how to open a 5 lever in 5 minutes
