[ukvac] Re: Standing TVs Vertically
Good point. As the cubs to have the vents on the side. A simple idea
would be to raise the monitor off its side a bit (with a few strips of
wood) leaving about 4/5 cm between the tabletop and the vents on the
side. This should improve airflow.
Matt
In message <009601bf370f$e910e960$82646464@compaq>, Phillip Eaton
<phil@pjeaton.demon.co.uk> writes
>Regarding all this standing monitors/telly's on their side chatter - Isn't
>it just a case of heat build up? (i.e. how to stop it?) Electric fields
>don't care much about gravity, do they? If you want to use it vertically,
>surely you can just drill some holes in the top and bottom to let the air
>through?
>Perhaps I'm missing something?
>Phillip Eaton
DATA Imported from archives: originally posted by Adam / Matt (thebrothersrose@adamr.demon.co.uk)
Matt
>through?
>Phillip Eaton
