Wells Gardner d2900 pulsing screen .. caps ?
7,368CR
Don't think i've ever seen an LG Philips crt on a WG D9200/D9400 monitor before but it's the correct crt as Grant says, and you can see the original WG sticker with serial number on it. Pretty sure every one i've ever come across have used RCA or Thomson crts whether it's semi-flat/curved or flat.
On arcade projects
The collective on yoke readings have this monitor listed with d9400
7,368CR
bad game board to use as they have an odd thing going on with the sync
I think your spot on ..
I was going to ask others that have this type of board if they can report this screwy sync
So I must have a partial vertical collaps on one of the chasiss
So will check / swap some caps in the vertical ic circuit to start with
7,368CR
Repaired 2’of these chasiss
Last week obvious issues
They had been chucked about and the large heat sinks on the kneck pcb and ones on the vertical ic also hanging off the pcb..
7,368CR
The chassis with vertical issue
Screen seems to be curling back on its self .. ( fold over but more of a curving round on its self.
Found an old thread same issue
It was C312 Reading 200 ohms in circuit should be 1.7k ohms.
New cap at C312 fixed issue so will try that cap
