Fart Carpet π€£Goodbye super old smelly fart carpet. π€’π€’π€’π€’π€’
You're going in the bin pronto. Honestly it absolutely stinks. π©π©π©
New one installed and looks and smells delicious πππ
Amazing thread, thanks for posting. I've never played on one but if there is one going in at Arcade Club then I'll give it a go there
What I want to know is how you moved this thing around doing the resto, I know you are a big lad but this is Geoff Capes material!!
Not sure if this is a repost from an earlier message but the issue is your -5v if you are only getting 3 flashes. The 4th and last flash is the speech chip test itself and it needs +5v and -5v for this chip to operate.Squawk and Talk doesn't work and stops on three flashes. I have a @myPinballs replacement and swapped that in, but interestingly that also stops at three flashes. A bit stumped and I'll need to look at this further. But need two functioning dual amp boards for it to work properly anyway so not an immediate problem.
