Simple thing about a game that you never knew......
LHantz
9 (100%)
315CR
You can easily beat that pesky red demon on the second level by unleashing the power armour, there are hidden chests as well, try running to the left when you start and then jump at the edge of the screen, one should appear.
LHantz
9 (100%)
315CR
Simple one, in Bubble Bobble, on level 1, fire loads of bubbles, then once you have killed all the monsters, pop them all and they give you item points!
MonkeyJuggleDX
260CR
Daioh US/World version has a 6 button layout.
1, 2 & 3 are normal shot, laser and missiles with 4-6 being the associated bomb for each.
Only just found out you can hold 1 & 3 to fire both weapons at once.
5,620CR
Thanks for the tip. The chest had a wizard bloke in it (as usual) and I got turned into a duck. 😆
Stokers
36 (100%)
1,989CR
Is there any sequence or logic to what's in the chests, or is it purely random? I just seem to get the wizard 9 times out of 10.
They aren’t random, the contents are in sequence but if you don't find the hidden chests the sequence will change (I think)
Stokers
36 (100%)
1,989CR
I didn't know for a while that in Marvel vs Capcom (and the other vs games) once you win a round, you can press start to cancel your win pose - you can then kick your opponents when they are down.
