So it begins
Rob_bob_2k6
3 (71%)
218CR
Seems like a really nice picture, quite a lot of metal slug 2 burn in on my one though which is annoying as the seller told me it was complete and burn free. Can’t see it most of the time even though it looks bad switched off.
8,144CR
As long as you can enjoy playing that’s all that matters ..
This has some burn ..
Can’t see it when playing IMG_6131.jpegcan see it in white back grounds
Insert coin and a square box around
Rob_bob_2k6
3 (71%)
218CR
It doesn’t really bother me in game, it’s not like the insert coin burn that you can always see on some driving cabs, but it is over a quite large area.
I’ve got the led panel marquees coming next few days to go in, always thought they were a bit of fun though not original to the u4, there’s loads of room to fit them in the marquee.
8,144CR
Yeh nice to have that all lit up!
Will be happy when I get round to all them bits .. got the nervous part to get through yet!!!
Doing same with a blast city at mo as well..
1,103CR
Holy molies ... looking amazing!
Little up date on the bungalow
CAN YOU BUILD ME ONE, NEXT?
Akira99
656CR
8,144CR
Hi mate hope you alright? So is the arcade room finished now then?
Im all good bud thanks for asking ..
Not quite . Needs finishing off on outside .
I want a window now as well down the end ..
also it’s half serving as a storage unit at mo for all my arcade related stuff!
I’m currently decorating for a kids play room
Since moving cabs into arcade room
1x SanwA pfx decided to loose red colour .. new neck pcb fixed that until I
Replace resistor on that.. but whilst I was at it I decided to swap the tube to the correct tube with correct yoke type for my chasiss .
Neo cab ..
Grant kindly checked over chasiss for me just for poss bad yoke killed the vertical I C last night!
So todays mission monitor swap ..
I have options
I have 4 nice nanao 25” also I pulled a B& O beocenter tube this week and
Paired with polo 2 auto
Last night I decided to put the groovymame into the tated egret 2..
Shmup Heven then resumed and calmness spread throughout the land
Bungalow ( my job )
Tiles & solar panels to fit this week
How’s you doing ?
8,144CR
I bought 27 cabs before I built the lean 2 so I did it arse about face but I like the sentiment ☺️.
Also been sucking eggs over monkey ball . Had to get another analogue stick as mo e was faulty! But until I had the replacement to confirm I was
Re wireing the loom all sorts of ways
Re calibrating . Etc . Pulling teeth with no joy .. but yep the analogue pots are toast . So I’m going to now as I have a faulty analogue stick anyways take it apart and have a go at replacing the 1k pots to 5k pots to see if that gives full speed to those pesky little monkeys !
( but what will it do to zombies revenge / cosmic smash / spike out etc.? ). Zombie revenge double speed might be fun 😉
Akira99
656CR
Neo cab ..
I have options
☺️😎View attachment 23587
Bungalow ( my job )
How’s you doing ?
I'm okay thanks fella just getting on with life like everyone else is:). Please keep me updated on the progress of the kids play room(y) and of course keep me update on the arcade room:).
