The spare bezel that I ordered from Mo at
https://www.videotronicsuk.com/ arrived today. Thanks for that mate. I only ordered it on Monday evening and it got here this morning. Super fast delivery. Thanks again.
Anyway I’ve installed it in the cab now that I managed to find my spare monitor spacers I’ve had a chance to install the monitor and try both bezels.
The original one which is the touring car bezel, definitely doesn’t fit. The curved section at the back of the bezel is too “fat”/the monitor is too far forward for it to fit. I sort of could see this happening when doing a test fit of the bezel before installing the monitor. Which is why I ordered the “flat” bezel from Mo.
It seems to be a bezel from a Japanese initial D machine and it has a very very slight curve on the back and is much thinner (the curve that is). So when I installed it, it fit!
The bezel touches the monitor at the top and bottom in the centre of the screen, however there are some gaps in the corners:
I plan on rectifying this with some Black Milliput and mould some into the gaps with some cling film or something similar so that it doesn’t attach to the monitor or bezel. When it’s set hard, I can then sand it flat and paint it with some Satin black paint that I used on my Pac-Man cabaret. Then I can either screw it into the bezel or glue it.
One thing that’s bugging me though is that the monitor seems to sit a little high. It does sit quite in the middle of the bezel vertically. I’ve checked and it would be the same with the original bezel as well. The dark bit around the viewable area of the monitor is more viable at the bottom than at the top.
The monitor frame sits nicely against the mounting posts so it’s mounted in the right place (I’m pretty sure all of the frames for these 29 monitors are pretty much the same looking at pictures).
Is that normal? I’ve never had one of these sit down cabs before and everything seems to be installed correctly. There are no adjustments that can be done to drop it down half a centimetre.
It maybe because I’m used to Naomi upright bezels that cover that black section around the viewable area of the monitor completely.
