7,138CR
R318 . One leg (left leg with heat shield at back of chasiss ) out off the chassis to have jumper wire solderd onto it to the cathode of the diode .
7,138CR
Thanks mate.
Appreciate that ..
And a clash of powers source aint going to end well! And it is at the top of my mind on this ..
As I understand -
One leg needs to be lifted out of circuit.
I have it like this as I remeber Rick neim saying “leg of r318 closest to the d506 lifted out “ image.jpgimage.jpg
Also there is the B through hole grant you say I could use for my jumper wire also
If it is in circuit between c313 and d506 ..
R318 right leg in , left leg out …?
M K L
1,033CR
Looks correct to me. If you take a pic of solder side we can be sure.
As for D506, you can solder the jumper wire to any of the yellow points (cathode), best would be B. White points are the anode (connects to yellow pad near the switching trasformer (see my previous pic). And of course you need to put a diode there. The part number in the schematics (30DF4) is not familiar to me (probably somehing Chinese). You can use RGP10J or BA157. And don't forget C333 (1000uF 35V).
7,138CR
Thanks
For that 👍
Will be back t it Monday 😊
