Wells Gardner d2900 pulsing screen .. caps ?
7,359CR
Yeh this monitor is kind of pulsing. In the top left & bottom left corner
See here
WG d2900 screen pulsing caps ?
Plan is to change these 4 large caps
These 2
2x 200v 390 uf
Being a digital chassis it’s litterd with ic ..
Anyone have any pointers as to why screen is pulsing ?thanx
7,359CR
degauss stuck on maybe, disconnect degauss coil and see if it clears
Yeh thanks grant I think you are correct
Even though I have not yet checked ..
Makes sence as I hade some gausing discolaration as well ..
Só this would mean i have constant current flowing in to The coil ?
Faulty PTC Thermistor ?
7,359CR
it would switch 12v to the relay, can you here the relay click when you press degauss button?
This type Controll pcb is without degause button unfortuanlty ..
I might have one somewhere ..
Maybe that might explain of I have the incorrect Controll pcb hmmm
Only got
Up down mode and select on the control pcb
7,359CR
Degausing harness was the culprit thanks .
One problem goes
A new one comes
I have a lovely 15khz image on this ..
But Can’t fill screen on left side . The raster bars squeeze up and stop as shown on left side ..
On my SanwA 27z I can shift screen using pots on the chassi. H v position Pots on the chasis ..
Anything like that or
Os this caps / componant issue ?
this is a secomd d2900
The original has same issue
Squeezed in vertical ..
Pin cusion
Trapazoid
Had no effect ..
Also cannot locate a demag in either factory or normal menu
Had to sort these two legs on this transistor also nos chassis but old and i guess they were just chucked about heat sinks pulled the compomamts out with it..
But super sharp 15khz image
I can go super large with the image só not sure if this has been modded at factory for a 33” showcase or larger
You
tb2000
3,252CR
That curling on the left is a vertical deflection problem. I think there's a few caps around the vertical deflection chip (STV8172 or TDA8172) that go bad. If it's a NOS chassis they shouldn't be (maybe some are a bit dry), but it's worth changing them anyway. I think it's only about 3 or 4 caps - I sorted the same problem for an op some years ago, it luckily in my case it was just a few caps. Have a look here to find the same problem and solution.
7,359CR
Hey man cheers
Yeh the caps In the vert deflection crossed my
Mind ..
I do recall reading this issue is normally caps ..
I have same issue going on on a SanwA 27c actually só if this works i can go on to do that one as well..
