Degausing harness was the culprit thanks .
One problem goes
A new one comes
I have a lovely 15khz image on this ..
But Can’t fill screen on left side . The raster bars squeeze up and stop as shown on left side ..
On my SanwA 27z I can shift screen using pots on the chassi. H v position Pots on the chasis ..
Anything like that or
Os this caps / componant issue ?
this is a secomd d2900
The original has same issue
Squeezed in vertical ..
Pin cusion
Trapazoid
Had no effect ..
Also cannot locate a demag in either factory or normal menu
Had to sort these two legs on this transistor also nos chassis but old and i guess they were just chucked about heat sinks pulled the compomamts out with it..
But super sharp 15khz image
I can go super large with the image só not sure if this has been modded at factory for a 33” showcase or larger
You
Can see the screen reduction on left
