Dragons Lair Control Panel Overlay Artwork Recreation.
conan
225CR
Thanks for hijacking my thread
As I mentioned, you may have your own color preference, but in offset printing, cyan is 100% saturated, magenta is 100% saturated, yellow is 100% saturated, and so on. If red predominates in Dirk's suit, that red will be a pure red, not an orangey version of the color sprinkled with yellow dots.
CMYK printing is already muted enough if not handled correctly without you lowering the color even further, but it's your file and your printed reproduction. I'm not interfering with your preferences; I'm stating an objective fact. I'm telling you this without any ill will.
Cheers!
Literally spent years working in offset...
Do me a favour and please stay out of my threads. I dont really like you or your attitude. I watched you get banned on Dragons Lair Fans for good reason. This thread has now been hijacked with you explaining how great you are and what people should do and your massive logo splashed over everything.
There are plenty of talented people doing this work who just keep quite and get on with it. Im now getting dragged into having to explain that i have been doing this much longer than you, professionally, for some of the largest companies out there and thats not what this is all about.
Mikonos11
92CR
Perhaps, maybe, you've been doing this longer; I can't deny that.
Don't worry, I won't participate anymore, and I'll continue to follow your progress with interest.:)
conan
225CR
Anyone thats worked proferssionally in this industry will know that what you see on screen (unless you are using a calibrated monitor) is absolutely not what you get in print.
So the sauturation level in these image has been setup for output on a specific press and is still a work in progress.
The original CPO's were printed and glued to a very thick lexan that has quite a rough texture (by todays standards). As I said I have roughness tested it and have found a close match in the USA.
The issues with scanning this artwork (from anything other than the original paintings) is that not only are you scanning a printed halftone pattern you are also scanning through almost a frosted surface that refracts the light, breaks up edge detail and generally causes quite a lot of interference.
The scan of the original top section artwork, while great, isnt much use when compared to the lower front.
Scan of original artwork top as compared to a scan of an original CPO front section.
As you can see contrast and detail are nowhere near the same.
I even considered painting in detail based on the original artwork as a reference, this work in progress screengrab shows a rough pass (that needs refining), but that wouldnt be failthfull to the original so I stopped with this concept.
Using AI or any tool that alters the original isnt of interest to me either.
The conclusion was that until the original artwork of the front section becomes available its pointless to attempt to incorperate the new scan with the old. They are just too far apart.
So what we are doing now is intergrating the colour pallett, contrast, tonal range, saturation and 'feel' of the original with my version to get something that will print out in good quality and reflect the art as originally intended.
I Hope to have an update on this later next week.
Mikonos11
92CR
Sorry, I couldn't ignore the challenge! :rolleyes:
*I think it took me longer to take the screenshot, rename it, and post it than the Photoshop retouching!
The color of the thorny bush is the same, or almost. I could refine it further!
*The screenshot is very large so you can see what I've done. I'm not a professional because I don't make a living from this; I do it as a hobby, so I've relied on my personal talent. :)
I hope I've solved the problem so our sherlockian friend can continue making progress. :geek:
CMYKhazi-Dan
Saikyo Style 💪
1,385CR
I hope I've solved the problem so our Cimmerian friend can continue making progress. :geek:
Don’t give up your day job! 😆 😉
conan
225CR
Of course, you couldn't resist because your massive ego wouldn't let you.
But, like a fool, you completely missed the point.
And this thread continues to be hijacked by the number one art prostitute in Greece, Spain? wherever....
conan
225CR
You are banned from KLOV / Musium of the Game, you are banned from DLF, you rip people off, and you have average Photoshop skills at best, all wrapped up in a ridiculous ego, arrogance, and a complete lack of humility or self-awareness. Ill ask you again to keep out of my threads.
conan
225CR
Thought I would share this as an exaple of screen art vs output print. This was generated from the original 'so called' desaturated artwork and as you can see its still saturated quite heavily and needs more work, espacialy with a colour shift in the blues. This was my first output test and I wanted to check it 'on game' rather than just look at a proof sheet or no test at all. Bit more work to do but i think we are really close to getting this looking good when I incorperate Brians colour space ref
from his original artwork.
I think its worth sharing a few ref images so you can get an idea of the saturation levels of original art. Remember the images are always subject to the colour temperature (kelvin) of the lights being used on location as well as the camera used and its settings / white balance etc...
The next image is possibly one of the most interesting, in that the detail of the thorns can very clearly be seen. This is a very rare control panel from an unknown (to me) version of the game.
The contrast and level of detail in this version is different and much superior to other original CPO's and reflects the original art much closer.
This is why research in my opinion is vital to correct reproduction/ restoration...
Ill update with new work on my art asap....
cools
I joined ages ago honest
18 (95%)
764CR
I'm not sure if we were first to do it (though I like to think so), but banned on Arcade Otaku too.
conan
225CR
Quick update. The scan of the original artwork has rquired not only stitching and distortion correction but a lot of retouching The cell overlay of Dirk and the snake has become bonded to the background, its out of register and quite a lot of the paint has started to come away. Been retouching it and putting everything back in alignment.
Before: Raw scan before work. Hair, scratches, miss aligned assets and debris all have to be looked after.
After: Cell is re aligned and everything has been cleaned up.
Here it is in all its glory. Ready for integration into the existing version. Hope to have an update in a few days.
conan
225CR
Another update. After a lot of thought, I have decided to try and pull back as much detail from the lower panel as possible, and as sympathetically as possible to the original art. The new top panel scan is lovely and has so much detail that it's a shame not to try and use it all.
It's a complicated problem in that the lower panel scan has halftone and material texture that disrupt the detail, but at the same time retains some of it. So, in order to get the two artworks to align, both have to have the same halftone effect applied.
The top panel is raw art, so it's easy to apply a fake halftone pattern to replicate the CMYK colour printing process. However, the bottom panel is a scan from a print (through textured Lexan), and the original art is "hidden." So I have started the lengthy process of removing the halftone and underpainting the lower scan, then reapplying the halftone in Photoshop.
This effectively recovers detail, and by flipping between the original scan and the new version, I can make sure I'm not creating detail that wasn't there (within reason).
It's a relatively easy technique (if you can use a tablet), just very time-consuming, and I have not done any colour correction or matching between the two panels yet. I'm blurring the sky and using a simple smudge tool to blend the detail of the thorns, dragon, etc., mixed with some cloning to sharpen edges and make things pop.
Here is an example of detail being recovered.
and a comparison of new art, old original scan and detail recovery:
As i said still got lots of work to do and lots of colour correction and colour grading to do yet.
ZedEx48K
8-Bit
1,404CR
Yeah, someone was after artwork in the Linux loader discord, warnings were fired off when it seemed op had to deal with Mikonos, guys really created himself a following! :D
