1992 mortal kombat restoration
musashi
13CR
Hi all, am hoping to turn back the clocks in this machine to make it look and feel as new. It has some cosmetic issues at the moment as well as technical (I have posted my technical issues already) here she is, any advice greatly appreciated:
pezley
44CR
I am currently turning my total carnage machine (same cabinet as your MK1) into MK2 and if it helps my thread is here
http://www.ukvac.com/forum/mortal-kombat-2-conversion_topic357167.html
I actually have the Control panel and front art already printed if you would like them cheap. Just cover the printing costs and postage and they are yours.
pezley
44CR
just to note, you can see how the control panel and MK1 control panel art look fit in my thread. I used one of them but have a couple spare
musashi
13CR
Anyone know how i would go about getting the buttons replaced? Some of them are sticking and not responding at all, would like to keep original colour buttons too cheers
2,253CR
You'll be able to undo a couple of brackets under the control panel inside the cabinet, the whole panel will lift out then. Check the underside of the buttons which are probably screw fit ones. Then you can buy the same colour and type from Arcadeworlduk, you want happ concave button.
5,199CR
musashi said:
sent you a pm mate, does anyone know how to fix that awful spray attempt in the last picture?
Yeah, sand it down, fill any bits and get some Satin Black Plasticote Spray and redo it black
My Double Dragon 2 went from this to that
musashi
13CR
wow! the paint job is impressive! im more impressed you have a double dragon II machine!
I have that game on Nintendo but I bet playing on the big screen is so much better!
pezley
44CR
do you want it with text or stick men ? Can make it up tonight and send you the image if you like, same as your MK2, just need the dimensions.
musashi
13CR
the stick men look better, will it have the detail on the dragon and the mortal kombat lettering?
My control panel is unaligned :( so might be tricky to fit new art?
pezley
44CR
The art is readily available exactly how you want it. If it needs adjusting to your cabinet though, send me dimensions and ill resize and give you the measurements to print it in.
pezley
44CR
musashi said:
ok great can give you those measurements tonight cheers!
Just seen what you mean by off centre..
Looks like the holes for all the buttons are shifted left but the sticks are centralized okay ?
option 1) print as is and it would end up looking like it does already but new and clean
option 2) provide measurements to the centre of each button and I can shift the artwork around it, whilst this would work you would end up with non centralised art on the control panel to match your non central buttons. I'll shift the button layout over half a cm tonight to the left and you can eyeball the art to see if it looks 'off' you may find that assets being moved looks worse then just the buttons not aligning.
Option 3) Get some MDF and create a new control panel with new properly aligned holes.
musashi
13CR
thanks! i think the previous art was cut incorrectly as the left hand dragon has more of a gap to the edge that the right hand side, which explains why the buttons appear off centre.
Would you recommend that I remove the the previous art to apply the new one? or apply on top of the existing?
musashi
13CR
measurements are in cm, to the centres of each button and joystick. Excuse the poor attempt at drawing a dragon! looks more like a swan!
pezley
44CR
hahaha perfect !
will get that drawn up in cad or something at the weekend and check the artwork will overlay correctly, if not ill make some changes to the artwork to cater to your control panel
