Advice Required Please
USDDan
6CR
Hi All,
I'm new here and new to classic arcade gaming - and I could do with some advice please...
I've recently bought a Taito cocktail arcade machine. I've done a bit of research and it appears that my machine was imported from Japan and was originally installed with a game called Field Goal but has had a Slap Fight board fitted at some point.
The machine also came with an uninstalled 276-in-1 Jamma PCB. The wiring in my machine looks original (it looks pretty bloody old anyway!!) but has had some extra buttons installed at some point and all of the controls work perfectly with the Slap Fight game.
My question is; does anywhere sell a wiring harness adaptor that will allow me to fit the Jamma PCB without cutting or soldering any of the machine's original wiring? I'd like to return the machine to condition of which I bought it in if required.
Any advice or suggestions would be very much appreciated!
Thanks,
Dan.
USDDan
6CR
Excellent, thanks.
You'll have to excuse me for being so uninformed; I know very little about these things or electronics in general!
The machine's original (or currently fitted) board is connected via 3 connectors. Is there anywhere where I could buy the male end of these connectors and the 28 pin connection that the Jamm board requires?
Thanks again.
5,658CR
Welcome to the forum.
As Ronnie says, get some pictures up so we can see what version of Slap Fight you have as there's a few with different pinouts.
chuckles1001
34CR
Looks like me and you are in a similar boat, I just got a taito that has had the wires spliced onto a gaplus PCB but a couple of wires have come loose over time, so need reconnecting but I do not know what Taito box I have. So want to keep my eye on this b4 I put my post asking for help up ;) Any chance we can get some pics.... Seems like the Jamma type option is getting more of a possibility now lol
USDDan
6CR
Please excuse the dodgy photography here, but these are the three connectors that currently connect the board that's installed in my machine.
USDDan
6CR
This is the multigame Jamma PCB that was supplied with my machine.
I was hoping to find (or at least make) a wiring harness that will connect the Jamma PCB's 56 pin connection to the male end (machine wiring loom end) of the three white connectors shown above.
Is this all there is to this or have I massively underestimated things here?
Thanks.
USDDan
6CR
Sorry, I had to crop the picture so it would upload on to the forum.
The wires are soldered to the original board.
I'll take a picture so you can see what I mean.
USDDan
6CR
This is how the machine's original wiring is attached to the current PCB.
Thanks, and thanks for all of your help with this guys!
Ronnie Dent
1,206CR
Well that's been hacked! wires are meant to be on an edge connector not hard soldered to the board. You would be best to just cut all those of and either make an edge to suit that board or just wire it to a jamma edge and get an adapter made to suit that board if you want to use it again.
Ronnie
USDDan
6CR
Argh, I didn't realise that was the case. Thanks for letting me know!
I've seen the Jamma connectors advertised for sale. Would the wires correspond to the Jamma board in the same order they do currently it is not quite that simple?
Ronnie Dent
1,206CR
it depends if that board is jamma, but probably best starting from scratch and tracing all the wires from source ie video,power buttons etc then fitting to new jamma edge connector
chuckles1001
34CR
Is your monitor CGA and and does that jamma support it? All the ones I have seen have the 15pin VGA, are you meant to wire a CGA monitor into a VGA connectoer to use it with CGA?
USDDAN there is a microsoft program called "Photo Gallery" its free and you can use it to make your photos under 1mg so they post here easy, you just save for emailing, hope it helps :)
bbz149
26 (100%)
1,608CR
Drives me f@cking nuts seeing boards soldered on because some lazy CNT cant be bothered to get an edge connector
I would buy a proper edge connector and transfer the Wires onto it, then clean the Solder from the board and get a fingerboard to Jamma and try and work out the pin-outs to make a proper converter
bbz1492015-06-29 19:57:44
USDDan
6CR
I've ordered a Jamma connector, but you're right - I need to make up a proper adaptor.
Does anyone know of anywhere (or anyone) that could make up such an adaptor? I've been searching around and found nothing, but I find it difficult to believe that this isn't a reasonably common thing to do and that there isn't someone out there selling adaptors.
I've emailed several people who sell these multigame Jamma PCBs - but they don't seem to want to know....
mathj
499CR
it is possible to make a jamma adaptor for your table from original wiring but the controls will be limited to what's fitted to the table
the upright manual is here LINK this may help work out what the wires are and how it was wired originally but the upright may be slightly different to the tabletop version
the original looked to be wired using 2 2x18 way edge connectors looking at the manual, I may have a few spare here if you want to go down the original wiring setup drop me a pm and I will post you a couple, from there you make a adaptor form field goal to jamma for jamma pcb's
math
