Alca Space Firebird U/R ( ex Duke Of Lancaster ship)
Ronnie Dent
1,159CR
46CR
This is great work, loving what you've done so far. I nearly bought this cab, and I'm so glad it's gone to someone with the skills and passion to make it original again.
I'm currently working on an Alca Snapper and, ironically, I'm at the same stage as you. I use chalkboard paint on my cabs, it's amazing stuff. It was recommended to me on here years ago and all my restorations get it. It goes on really well and covers a multitude of sins.
I'll get a picture of the paint and upload it. I will start a thread like yours soon, keep up the great work, top job!
46CR
It's lovely paint in my opinion, definitely worth a try to see if you get on with it. It's very durable and blends into itself well if you need to touch it up, it looks very matt in the pic but its not so much in real life.
Ronnie Dent
1,159CR
Thanks, that looks great blazefazer! Would be good to track your progress with it too, was yours complete inside? Also be good to see some pics to compare as I have little to go on, thanks for posting, paint wise I'm using what I had which is Dulux masonry black but it's probably more matt than yours by looks
Cheers Ronnie
46CR
I have the Alca Planet from the same chap. I got it working and will give it a light restoration at some point. It was totally complete and original when I got it. It's actually the identical cabinet to yours, whereas the Snapper is a slightly different variant that Alca did. I'm happy to share anything you need. I can post some pictures here or DM them to you, whichever you prefer. I don't want to hijack your thread with my stuff!
Ronnie Dent
1,159CR
Brilliant cheers, If you could message me some pics that would be great
Ronnie Dent
1,159CR
Having looked at other Alca cabs inc Frazers they all seem to have art on the glass bezel, this makes me thing mine should have, but as far as I know the only image that exists is of mine, you would think there would be more lurking somewhere
501631560_24701839119405051_2469878358184624956_n.jpgScreenshot 2026-06-11 at 11-03-56 1 vintage arcade cabinet video game machine by ALCA type Gal...png
qjuk
50 (98%)
1,852CR
Managed to get the screen fitted, intervideo 17” nos, I believe it can run a 19” crt so maybe prospects to upgrade later
View attachment 59282View attachment 59283View attachment 59285
Hi Ronnie,
Can I ask if you have tried getting a picture on this monitor in its current position?
The reason why I ask is that I’ve also got one of these 17” NOS monitors from Dave Wallace. On mine, if you position the monitor horizontally and upright you get a perfect crisp picture. As soon as I position the monitor at 45° degrees (like in your picture) I get colour purity issues. The same happens if I try and mount the monitor vertically, the colours go weird on the left side of the screen (red goes orange, blue goes purple and green goes turquoise).
I just wondered if you have got the same issue with your monitor?
Ronnie Dent
1,159CR
Not got to the stage where I have a signal hooked up to it yet. I may get the same issue, that’s something to look forward to lol, is it not a degauss issue?
Thanks Ronnie
qjuk
50 (98%)
1,852CR
No, it’s definitely not a degauss issue. I thought that at the time and have tried a degaussing wand several times but it makes absolutely no difference.
If you tilt the monitor whilst hooked up to a test colour pattern, you can see the colours change.
I’ve had a similar issue before with a colour vector monitor. The monitor was factory set to horizontal, but rotating it vertically gave me colour purity issues. In this instance moving the machine to a different location pretty much solved the colour issue.
In the case with my 17” LG/Philips tube, no amount of moving drastically improves the picture (apart from standing the tube vertically upright in a horizontal position - then the colours are perfect). Great for a candy cabinet, but no real use for a lot of cabarets which tend to have the monitors mounted at 45° :(
5,653CR
I had this issue once. Just turning the monitor round slowly affected purity. I figured maybe the shadow mask was loose and was being affected by magnetic north. God knows. 🤷‍♂️ I basically had to dial in the purity rings as best I could once the cab was in place.
cools
I joined ages ago honest
18 (95%)
739CR
I've had the same with one. I found I had to degauss it with a brief pulse with an external coil (which means having to check the image to see whether that pulse was successful) rather than rely on the PTC.
Ronnie Dent
1,159CR
That’s the inside painted black and a board made to mount the boards , used a non working set to plan the layout, was hard to know how they were originally attached behind the monitor in the only image I have of how it was!
This is my guide picture
Ronnie Dent
1,159CR
All the wiring is done and the game is up and running, no issues with the image, having sound board issues ! One has no sound, the other has sound but the starfield is not right and it causes the whole screen to light bright randomly!
I will post some pics once I get the sound board issue sorted
Flyback2021
35 (100%)
1,911CR
Great job ! Looks amazing
