Asteroids problem
petercasino
212CR
Hi,
I've got an Asteroids cocktail machine that was fully working until I switched it on last night. Basically the player 1 and 2 start lights flash (it's set to free play) and you can start a game. When the game starts, the sounds work but you only see the ship and it's bullets. Any ideas what might be causing this? I'm new to arcade repairs (but can use a soldering iron etc and have repaired pinball pcbs) and want to make sure I don't make things worse.
On a separate note, what mods are best for me to do to the machine to prolong its life? I was planning on replacing the big blue capacitor and the pcb connector. Is there anything else I should do?
Cheers,
Mike
Equites
Chief Sheesher®
35 (100%)
3,329CR
What about the flying saucers? Can you see them?
It could be your brightness wants adjusting, just a wild guess without seeing what you are seeing.
Equites
Chief Sheesher®
35 (100%)
3,329CR
petercasino said:
Yes the saucers do show. I've not adjusted the brightness, does that imply something might've gone wrong with the monitor?
Not necessarily, although pots do drift over time, and can tarnish.
Have a look in the rear of the monitor, on the large board there will be two pots with wheels, one is white and the other black.
They should be labelled on the board, look for the brightness pot.
Very slowly, turn clockwise until you can see the asteroids. Be very careful to not over do it and turn the brightness too far up. Otherwise you can suffer permanent phosphor burn in the worst case.
space_invader
22CR
sounds to me like there is something wrong on the pcb, somewhere around the parts that draw the missing parts there could be a dead component or a broken connection. I don't really know the ins and outs of an asteroids pcb so I could be wrong but that is where I would start looking.
petercasino
212CR
Ok, adjusting the brightness has done the trick! Seems obvious now, but because the ship and saucer were ok I wondered whether it was a pcb problem too. Thanks for your help.
In terms of mods I should do to the machine, any other suggestions?
Cheers,
Mike
