Asteroids weird beeping?
Mr Bond
76CR
Anyone had this sound before on asteroids? Game sounds are there but its got a continuous mystery ship beeping noise?
https://youtu.be/9fVvKunODoY
Mitchell Gant
888CR
My guess would be the 4016B chip at location N10 has failed, but could also be chip N9 (7406, pin 12) stuck low 0V, or chip M10 (74LS259, pin 4) stuck high 5V.
If you had a logic probe or voltmeter you could test the pins I mentioned to confirm if they were stuck, but my bet would be the 4016B needs replacing.
Mr Bond
76CR
Thanks mate. Think I’d prob be as well buying one? Seen one on amazon for about £12
Laser 5263 Logic Probe DC https://www.amazon.co.uk/dp/B006IRIP8I/ref=cm_sw_r_cp_tai_v2vrDbG2MZADA
Would that do or is it cheap crap?
Mr Bond
76CR
Ok so I’ve changed chip N10, no difference
Checked N9 pin 12 and it reads 5v
Checked M10 pin 4 and it reads 0v
Can anyone point me to the schematics that indicate what pins should be doing what?
Cheers.
Mitchell Gant
888CR
Hmm, that's a puzzle then!
Schematics can be downloaded here:
https://www.mikesarcade.com/arcade/manuals.html
If N10 is changed and working, and N9 pin 12 is at 5V, then what it should do is turn on the switch in N10 and connect pins 1 and 2 together, shorting the signal (pin 2) to ground (pin 1). That should prevent the sound signal getting through to transistor Q6 base.
Can you tell us more about what led to the fault appearing?
Did you just turn it on one day and the sound was there? Had other repairs been done just before? Had the PCB been removed/re-installed and it started? Etc..
A broken PCB track from N10 pin 2 could cause the fault. Maybe the PCB has been damaged by mishandling and broken it for example. You could manually connect Q6 base to ground with a wire and see if it stops the sound then.
You're past the obvious simple faults now :-(
Nes4life
1,134CR
Hey! So this is definitely the saucer sound firing when it shouldn't.
On a working PCB M10 pin 4 should stay around 0v when the saucer is not on the screen.
This signal is called 'SAUCRSNDEN' in the schematics.
This leads to N9 pin 13 and this is inverted on pin 12. However, you should be reading 12V on N9 pin 12 as it is connected to 12v via a 1K pull-up resistor (R85).
This pulled-up signal is then fed into N10 pin 13.
Please check that you get a reading of 12V on both pins of R85 (it's located to the bottom right of N10 on my PCB).
Mr Bond
76CR
Hi. Got the cab from coin op a few months back. It was like this when I got it. Changed it over to 240 with the jumpers and powered it up. Monitor was dodgy but the game played. The game runs and plays perfectly fine aside this ufo noise. I recapped the board and the monitor, and the PWR supply, new big blue etc. Game runs perfectly now except this sound fault.
I think the board has been repaired before looking at it. There’s a few jumper wires on there indicating broken tracks in the past, but aside that it’s really clean as is the whole inside of the cab.
Mitchell Gant
888CR
Phill, I think you mean pin 2 there? Pin 4 is saucer sound select part isn't it?
R85 being faulty could do it though if it doesn't turn on N10 properly.
James (that is your name, right Mr Bond?) said he read only 5V on N9 pin 12, but was that with a voltmeter or did you just read a 'high' with your new logic probe?
As Phill says, you need to read the voltage on both sides of R85, or preferably on N10 pin 13 to be sure it's being properly pulled to 12V. (Use you multimeter set to voltage)
Nes4life
1,134CR
The schematics I'm using show SAUCRSNDEN coming from M10 pin 4 and connects to N9 pin 13, is inverted at N9 pin 12 and connects to N10 pin 13 via pull-up resistor R85.
SAUCERSEL comes from M10 pin 6 and connects to N9 pin 1, is inverted at N9 pin 2 and connects to N10 pins 5 and 6 via pull-up resistor R63.
Edited photo of schematics to clarify:
https://photos.app.goo.gl/Kcd9mKRzFgY34XrAA
Mitchell Gant
888CR
Ah, you're right, I was getting my 'M' and 'N' confused there, I was thinking you meant N10 pin 4.
As the fault was already existing rather than had been working then developed whist playing, it means there is more than just chip failure to consider now.
Mr Bond
76CR
Yes I used a multimeter to check the voltage. I’ve got a probe but couldn’t see where to connect it up to so just used the multimeter.
I’ll do some more testing tomorrow. Cheers guysMr Bond2019-09-03 20:37:10
Mr Bond
76CR
Tested R85. 12v going in, only mV coming out. It’s dead. Same with N10 pin 13.
Looks like I need a 1k resister. Mr Bond2019-09-12 18:55:14
Equites
Chief Sheesher®
35 (100%)
3,332CR
That's not how you test a resistor.
Seriously, you've given it a good shot, maybe time for a repairer to look at it.
