Hmm, that's a puzzle then!
Schematics can be downloaded here:
https://www.mikesarcade.com/arcade/manuals.html
If N10 is changed and working, and N9 pin 12 is at 5V, then what it should do is turn on the switch in N10 and connect pins 1 and 2 together, shorting the signal (pin 2) to ground (pin 1). That should prevent the sound signal getting through to transistor Q6 base.
Can you tell us more about what led to the fault appearing?
Did you just turn it on one day and the sound was there? Had other repairs been done just before? Had the PCB been removed/re-installed and it started? Etc..
A broken PCB track from N10 pin 2 could cause the fault. Maybe the PCB has been damaged by mishandling and broken it for example. You could manually connect Q6 base to ground with a wire and see if it stops the sound then.
You're past the obvious simple faults now :-(
