ATARI Battlezone
leslie
42CR
wondering if any one has the answer to this question? I have just received some b/z boards back from being repaired, when in fitted them it blew fuse number 3 witch was 3A 250 volts i checked in the manual and it said it should be 20A 32 volts, seems a bit high also why 32 volts and not 250v some one please help!
obcd
3,830CR
Fuse voltage isn't that important. The fuse has to be cabable to stop the voltage it's connected to. A higher safe voltage is better. If the fuse is in the 5V or 12V supply line, 32V is enough but 250V will work equal well.
Equites
Chief Sheesher®
35 (100%)
3,329CR
The F3 fuse is for your 10VDC. I would check your edge connector on the PCB stack. Make sure the pins are intact and not shorting against each other.
Have you done any work on the cab prior to the PCBs returning?
ColinD
6 (86%)
1,367CR
Right... UNPLUG the Output on the PSU Brick and do some Voltage testing with a meter.... Make sure you have the BROWN WIRE plug inserted on the voltage selection.
There is a similar thread in the sticky's based on Starwars and a lot of this is quite similar and you can relate to this.
F3...That's the Main Fuse that drives the rectifier and pumps up the Big Blue capacitor. When first powered up, there will be quite a current surge, hence high rated fuse and 'slow blow' nature.
Next up is to check the AR2 Board is working correctly chained up to the Power Brick (AR2 output to game board unplugged).... I'd also strongly suggest that you do the sense mod.
ColinD2014-11-21 20:23:48
RGP
Meeter & Greeter
2,039CR
Definitely only replace F3 with 20A slow-blow 1.25in fuses, there's a high current draw across that fuse on power up and because the AR2 runs the amplifier as well then it'll keep surging with the up/down draw on current from the amp. Quick-blow fuses will pop a number of times with no apparent problem and work fine when replaced for a while - and you'll think you've got problems elsewhere.
Colin is very familiar with BZ's and the weird quirks of Atari cabs.
We have a Star Wars upright that keeps blowing the F3 now and again but we were putting quick-blow fuses in at 15A and it was working fine. Our brick for that machine had been fully serviced with new big-blue and bridge rectifier and the AR2 had been soak tested thoroughly.
RaveN
1,325CR
Nah, the F3 fuse has nothing to do with the AR2 amp, even if it did, the current draw from the amps (which is what 4-10watts? is negligible.
There's no quirks with Atari ARs, they're one of the most simplistic and reliable pcbs out there.
Upon replacing a few parts, I've NEVER had any issues with AR1/2/3s.
The fuse is a 20A slow- blow because the big blue (like any cap) is effectively a short when first powered on (hence the 35A bridge).
To determine why it's blowing, disconnect the AR2. If it still blows then it's either the bridge or the cap (unlikely). If it blows with the AR2 connected then it's likely (although not definitely) going to be the 5v main transistor (a common fault).
Equites
Chief Sheesher®
35 (100%)
3,329CR
I think Battlezone has the two large discrete diodes instead of the square bridge rectifier.
I rebuilt an Asteroids Brick once, and on the rectifier board accidently shorted one of the diodes which resulted in the F3 fuse popping.
School boy error.
