Atari Cone Behaviour
virtvic
The Cabaret King
21 (96%)
2,012CR
I wired up the cone leds on my dig dug tonight (LED wires from edge connector and +5v) and they seem to be on all the time.
Shouldn't they be off, unless a coin is inserted, then they should blink?
4,058CR
Ok, mine flash - and mine's a Namco board so I would think that an Atari board is all the more likely to flash. That's the reason I asked, I wasn't sure if the Namco board flashed the LEDs or not and I wasn't near the machine.
I guess they might stay on all the time if you have the leads reversed?, but I wouldn't want to get them the wrong way round in case it did anything nasty to the LED! Just to be sure, with the switch facing in a way that the two LED wires are on the right hand side of the switch (looking from the back), I have the black GND wire on the very right hand edge and the red 5v wire just to the left of it, on the bottom edge of the switch. The other wires just relate to the actual switching so won't have any impact on the LED.
From there it's going to be PCB time
I can take a pic of the back of my buttons if it helps you to be sure they're wired up right, and I'll let you know where to look on the PCB a bit later. Do you have ANY troubleshooting kit at all for the PCB? (I know you've sent stuff to me in the past) I think even a logic probe will do in this instance as it really shouldn't be complicated...
Purity
The Oracle
2,999CR
Definately worth a picture of the back of the button to see how it is wired.
I initially wired one of mine incorrectly and the button stayed on permanently, until done correctly
4,058CR
If it's the board then it's pretty simple to be honest, following back from 'LED1/2' there is a 220 Ohm resistor to verify is ok, then there's a 7406 which should just invert the signal, then pretty much the only other thing to verify is the pull-up resistor attached to the line, R152 for LED1, R151 for LED2.
I admit that I don't know if I'm looking at schematics for Namco or Atari boards so the part designations could potentially be wrong. Sheet 5B of SP-203 drawing package though.
All that assumes that when the game is coined up, the output from the custom (@ 11P) are toggling on and off. If they're not, and all the other controls are ok then it _COULD_ be the custom. But I'd say it's unlikely. Far more likely to be the pull up resistors or something like that.
virtvic
The Cabaret King
21 (96%)
2,012CR
Out of interest, was there a Namco made Dig Dug cab? or were there just Atari cabs with different boards in them?
My original manual has a drawing of a 2 layer board in it.
ataritoobin
199CR
This is the model advertised on the Japanese flyer (can be yours today for only
60,000 yen!). That dedicated Xevious in the "Galaxian" type cabinet showed up last year (Xevious was released in Japan in December 1982, Dig Dug in January 1982, according to Dragon Spirit
), so I suppose it's possible Dig Dug also came in that cab.
Namco uprights and cocktails of that period had/supported flashing start buttons as well.
ataritoobin2012-03-05 18:14:51
ataritoobin
199CR
There's some more pics on the auction page:
http://page7.auctions.yahoo.co.jp/jp/auction/g107929791
Interestingly enough, seems Tehkan built that cabinet.
EDIT: Just saw that the Namco flyer specifically mentions an ウップライト(upright) cabinet, so there probably was one available!
EDIT EDIT: Namco marquee!
ataritoobin2012-03-05 19:21:36
virtvic
The Cabaret King
21 (96%)
2,012CR
Right - a bit of an update.
I tried all 3 of my working boardsets. ALL produced the same results.
P1 cone remains lit all the time.
P2 cone works as it should do - unlit when no coins are inserted, blinks when coins have been inserted.
I swapped around the wires to the cones and they both work as they should do when attached to P2 LED wire.
Note - I am using the cones that have 3 terminals for the switch and only 2 for the LED.
There are 220 ohm resistors in the molex plug before the LED wires get to the cones. They both meter at exactly 220 ohms.
This is driving me BARMY!!!
4,058CR
Right, so let's see if I understood that correctly.
Both buttons operate correctly when wired to P2 LED wire. So both cones are confirmed good. That by rights leads us to a board fault.
BUT, you have 3 working board sets (lucky sod!) and they all do the same thing. So that leads away from a board fault.
Both 220 Ohm resistors in the connector meter out ok. Can you confirm where the resistors are? Which pins they go between etc.?
[EDIT] This is kinda pointing to a fault in the loom but I'm trying to get my head around what / where.guddler2012-03-05 22:47:34
virtvic
The Cabaret King
21 (96%)
2,012CR
This gets weirder. I metered the LED terminals at the edge connector. P1 LED stays solid on and P2 pulses.
All 3 of my boards do this (well, 2 I know of, I'll check the last one tomorrow sometime)
I'll do a little sketch of the plug and resistors tomorrow also...
